Bluetooth PCMCIA Adapter
Old Jan 20, 2015 | 06:32 PM
romanowski15's Avatar
S550
HI everyone has anyone tried this?? Wondering if this would work..
http://fr.brainboxes.com/files/catal...-card-bcsp.jpg
Old Jan 20, 2015 | 11:58 PM
Mike5215's Avatar
2016 C300
No. BT audio requires a special protocol (A2DP). Those units are intended for commerical use to monitor equipment.
The PC Card slot in the car is set up to receive a memory card
Old Jan 22, 2015 | 11:06 PM
Garticus's Avatar
W221/S550
An SD card for a standard PCMCIA adapter is pretty cheap. I thing I got a 8gb micro Sd with the SD adapter for under $10 @ Walfart.
I have way more songs stored on it than on my phone. (About 1000 songs)
32 & 64 gb cards will hold several thousand songs.
But you probably wanna stream Pandora/I Heart Radio or some music app from you phone.
Old Aug 11, 2015 | 05:45 PM
DaveW68's Avatar
Veteran: Army
2015 S550
Mike, I found the following PCMCIA Bluetooth adapter which allows the A2DP format. What are your thoughts on this? Would it allow me to stream music from my phone to me car? My car has a build date of 1-06 and does not have the RCA jack inputs....so I'm looking for another way to stream music.
http://www.psism.com/pcabt1.htm
Old Aug 11, 2015 | 09:45 PM
Mike5215's Avatar
2016 C300
I'm thinking the problem isn't with finding a card that's Bluetooth enabled but rather getting the car to know what to do with the output. The car is set to treat the card as a mass storage device, so it's looking for a directory and file structure, and then for MP3 files. Instead it's getting audio output and I don't think it's going to be able to make sense of it. But it might be worth getting one to experiment with.
Old Jun 3, 2021 | 07:22 AM
Numair Aidroos's Avatar
EQC, S Class Extended, Grace CVT.
Did this ever work for you? Did you try it?
