screen mirroring device
#51
Um, why two air fresheners? What are you trying to mask? ;-p
What is that coiled cord? Radar detector?
Excellent work Nick! "OK Google" can provide you with a lot of voice-controlled functionality.
Also, here are a few other options:
https://play.google.com/store/apps/d...gnifis.parking
https://play.google.com/store/apps/d...toit.assistant
https://play.google.com/store/apps/d...randall.nutter
Cradle option:
http://www.gtacarkits.com/product/me...-phone-holder/
Not nearly as pretty or classy as the Kuda solution, but does put the phone closer to the driver and has a decent included cradle that has angular adjustments.
Cradle option:
#53
2009 S550 AMG sport pckg. 2014 Ford F-150 Lariat Supercrewcab
I wouldve totally gone with the allshare but the whole hcdp thing makes it harder to find a hdmi to analog solution. Boooo to mercedes for not putting in a digital input. I wonder if theyll ever make a screen mirroring device that integrates into the MOST fiber optic ring. That would be the cats pajamas but doubtful theyll ever do that
#54
On the noise, you can try wrapping some chokes/ferrite core filters around the power input and composite leads.
Lastly, just FYI, I was able to locate a (just one) ignition switched 12V under the driver side. The twist was that the engine had to be running. It was not energized when accessory was on (ignition on position 2, not 1). Maybe there are sources on the passenger side that behaves the same way....
#56
Im going to get some shots of the screen mirroring device in action today and a video. I tried playing the halo 5 high def trailer from youtube last night and it looked pretty badass.
#62
1 Post
2013 S63, 2018 S63 with Carbon Ceramic brakes
#63
How to hook up ez cast using bluetooth
Allshare Cast Hub:
Amazon.com: Samsung Wi-Fi All-Share Cast Hub, Wireless HDMI Display Adapter (Black): Computers & Accessories
Or other DLNA, Airplay, mirroring device, etc.
Add this:
Amazon.com: enKo products Mini Composite HDMI to RCA CVBS AV Converter (Input: HDMI; Output: AV) for VCR DVD 720P 1080P with High-Speed HDMI Cable (6.5 Feet / 2 Meter): Electronics
Plus:
Amazon.com: Audio / Video AV 3.5mm to 3-RCA 5ft Composite Cable for Canon Camcorders - by CyberTech®: Electronics
And VIM, and you're all set!
WiFi mirroring will be better than BT...
Add this:
Plus:
