Best place to run a wire through firewall from engine?
Old Apr 2, 2015 | 05:45 PM
Jason B's Avatar
W140 Mercedes S350, W221 S550 sport
I'm about to install a front camera (will activate by hitting steering wheel button with custom programmed VIM) , and front camera will by mounted in the lower grille.
I need to find a way to run that wire from the lower front grille, to inside the car to connect to the Midcity VIM which is behind the in dash 6 disc changer.
Any advice here? Would prefer not to drill any new holes.
Here is wire that needs to come in:
Attached Thumbnails Best place to run a wire through firewall from engine?-image-3880238587.jpg
Old Apr 2, 2015 | 06:40 PM
natcahd's Avatar
Veteran: Air Force
2023 S580 (Current) 2011 S550
Jason...I put my VIM under the steering wheel column area. Would be easier to get a wire to that area. Just a thought.
Hd
Old Apr 2, 2015 | 06:47 PM
Jason B's Avatar
Sent you an email.
Old Apr 2, 2015 | 10:25 PM
alexandercat76's Avatar
2010 S550 4Matic
Originally Posted by Jason B
I'm about to install a front camera (will activate by hitting steering wheel button with custom programmed VIM) , and front camera will by mounted in the lower grille. I need to find a way to run that wire from the lower front grille, to inside the car to connect to the Midcity VIM which is behind the in dash 6 disc changer. Any advice here? Would prefer not to drill any new holes. Here is wire that needs to come in:
Through the fuse box under the hood drivers side, there is an rubber plugs will keep it weather proof. Also it's the easiest way to do and no drilling required
Old Apr 3, 2015 | 02:27 AM
Chris The Swede's Avatar
W222 S63L, ML/GLE350
+1
Old Apr 14, 2015 | 01:48 PM
Jason B's Avatar
Getting closer...
Old Apr 15, 2015 | 04:12 AM
snovvman's Avatar
I'm your huckleberry
Looking good Jason. I see that you have the module running. You just need to connect up the camera now?
Old Apr 15, 2015 | 06:19 AM
Nuru's Avatar
S350 BT 4MATIC
Hey Jason, how about some pics of your harness run from the camera location to through the firewall?
Old Apr 15, 2015 | 10:07 AM
Jason B's Avatar
Correct. Just been too busy. Probably this weekend. Some test fitment pics of cam attached below.
Soon... Here's just a test fit of the cam.
Attached Thumbnails Best place to run a wire through firewall from engine?-image-2079149577.jpg   Best place to run a wire through firewall from engine?-image-2890914527.jpg
Old Apr 16, 2015 | 05:50 PM
Nuru's Avatar
S350 BT 4MATIC
OK, can't wait to see those pics. Hey what are you gonna do to protect the camera lense from road debris?
Old Aug 17, 2015 | 01:15 AM
Jason B's Avatar
Ok, is this you mean? Remove the cover on the top right side of this pic? (looks like 2-3 allen screws holding it in place?) Then I'll see a place to run the RCA cable through?
Need to run the white connector through.
Attached Thumbnails Best place to run a wire through firewall from engine?-w221_driver_side_engine.jpg
Old Aug 17, 2015 | 01:12 PM
Jason B's Avatar
Ok, well, that was easy. After I popped the box off, I could see light shining in from inside the car. Was able to get the wire into the engine bay fuse box in 2 min!
Now the issue is getting the wire out of the engine bay fuse box... At the front of the box there is a blank square rubber grommet that pulls out! Guess just poke a hole in it and that's it?
Attached Thumbnails Best place to run a wire through firewall from engine?-w221_engine-fuse-box.jpg   Best place to run a wire through firewall from engine?-w221_engine-fuse-box-blank-square-grommet.jpg
Old Aug 20, 2015 | 08:26 AM
2010 S550 4Matic
Exactly, small hole, this rubber is really stretchy
