Tire Pressure Again
Old Sep 4, 2015 | 06:39 PM
natcahd's Avatar
Veteran: Air Force
2023 S580 (Current) 2011 S550
Tire Pressure Again
Look at these two Pics. Made three calls to different dealers. Two said whatever is on the gas door. Other said depending on season. On one of my past services from same as gas door dealer I left with pressures 36 and 38 front, 40 and 41 rear. Confused . Non 4matic.
Hd
Old Sep 5, 2015 | 05:55 AM
mrbobby's Avatar
2003 S500 4Matic (SOLD) + 2004 S55 (SOLD) 2005 CLK 500 Cabriolet 2008 S 450
I, naively, expect Mercedes dealers to set the pressures at manufacturer's specifications. Some will and in this case I would expect the fronts at 31 a nd the rears at 32 assuming average speeds under 100 mph and normal passenger load. Some techs erroneously believe they are doing you a favor in over inflating to the max in an attempt at increasing MPG or their ideas of good handling. Why this happens is beyond me but has happened to me many times.
Old Sep 5, 2015 | 06:52 AM
jfz219's Avatar
2019 ES300h
There are two issues with this TPMS warning. There should be no warning given for an over-inflation of the tires. I suspect that the internal settings of the TPMS are those of the 4-matic (38-39 PSI) and the fuel door label is the staggered spec.
Secondly, for those of us in the north climates, if the servicing is done in the winter, I expect tire inflations to be higher than recommended for two reasons. The service bay is much warmer than the outside temp. Tire pressures drop about one PSI for every 10 degrees fall in temperature. Additionally, in very cold conditions, the valve stems can stick when adding air. So topping off outside has its risks.
Old Sep 5, 2015 | 09:41 AM
natcahd's Avatar
Veteran: Air Force
mr.b & jfz thanks. So the dealer reset to incorrect settings on previous visit? Are they supposed to add for the +4 psi? Looks like a trip to dealer is in order.
Hd
Old Sep 5, 2015 | 05:44 PM
Popo Here's Avatar
2008 S550 4Matic
Reset the tpms. Push arrow down and it's going to ask you to use current settings. Press ok. Those will be the new settings for the + or - 4
Old Sep 5, 2015 | 07:35 PM
natcahd's Avatar
Veteran: Air Force
Popo...got it.
Old Sep 5, 2015 | 08:00 PM
Donnymac's Avatar
63 Falcon vert
Natcahd I had the same warnings recently and reset each time as Popo described. Not sure why the warning returned or started in the first place. I am hoping TPMS does not have a glitch emerging.
Old Sep 6, 2015 | 10:53 AM
natcahd's Avatar
Veteran: Air Force
Originally Posted by Donnymac
N I am hoping TPMS does not have a glitch emerging.
I hope not!
Hd
Old Sep 8, 2015 | 08:37 AM
triniexr's Avatar
2011 Mercedes S63 AMG
This is from my Canadian spec 2011 S63.
Old Sep 8, 2015 | 11:36 AM
Jason B's Avatar
W140 Mercedes S350, W221 S550 sport
It depends on wheels size also. You have factory 20's right?
Old Sep 9, 2015 | 03:58 PM
natcahd's Avatar
Veteran: Air Force
Jason....yes factory 20's
hd
