Squeaky Front End
Old Jul 6, 2016 | 06:27 PM
yankees1's Avatar
2008 cls550
Squeaky Front End
On my 2008 S550 with 70,000 miles I have experienced no squeaks from the front end until both struts were replaced and now VERY squeaky on non-smooth roads. Ideas ?
Old Jul 8, 2016 | 01:50 PM
jagno's Avatar
S550
Yankees1 Squeaky Front End
Check your lower arm and the sway bar.
Old Jul 8, 2016 | 02:35 PM
yankees1's Avatar
2008 cls550
Thanks ! Car in now for inspection ! I will mention this to them !
Old Jul 17, 2016 | 11:41 PM
yankees1's Avatar
2008 cls550
Squeaky front end no longer squeaks ! The dealership greased the front suspension and now rides quietly !
Old Jul 18, 2016 | 12:18 PM
bensitto's Avatar
S550, R350, GL550, ML63 AMG
Its most likely the front sway bar that causes this really bad squeaking. The 2 contacts where the rubber mounts are is the cause. Grease works.
Old Jul 18, 2016 | 11:19 PM
bmwcrocop's Avatar
2007 s550
What type of grease should I use; have the same issue
Old Jul 19, 2016 | 03:07 PM
bensitto's Avatar
Grease works as a temporary solution and solves the squeaky cracking over bumps and humps... but the correct procedure to remedy the problem is the epoxy solution.
You can download the dealer repair instructions here: (Step by step with photos)
https://mbworld.org/forums/attachmen...ay-10857-2.pdf
Good luck!
