Lower control arm torque and engine fault code (misfiring)
Old Aug 5, 2016 | 12:39 PM
HurtfulGuide8's Avatar
2001 S500; 2008 S500; 2013 Sprinter
Hi everyone, as the title says I haven't been able to find the correct torque measurments to tighten the front lower controlarms on a W221. The second thing I'd like your opinion on is a engine fault code:
* 0990 - cylinder 3 - too low currentflow through primary circuit coil - intermittent
My car was misfireing bad and had the engine light on so I got it diagnosed, turned out the misfire was caused by ignition coil on cylinder 8, I replaced the coils on both cylinder 8 & 3, the check engine light went away but the car is still misfireing (although not that bad anymore). My question is, how do i fix the "too low currentflow through primary circuit coil"? What needs to be checked/replaced?
Old Aug 5, 2016 | 08:52 PM
gsholz's Avatar
2013 S550 4Matic
Either the new coil is bad or there is a bad electrical connection.
If you are handy with a digital voltage meter you could test resistance of the primary coil and compare it to a good one.
Old Aug 5, 2016 | 09:05 PM
alx's Avatar
alx
Primary coil is in the controller side. Secondary coil is on the spark plug side. Either you have a bad wiring from controller to coil or bad controller.
