how to reset abs and esp
Old Aug 7, 2016 | 02:49 PM
Lamont's Avatar
2009 s550 4 matic
is there any way to reset codes without going to dealer or without code readers? ive corrected the issue just need to reset! help lol
Old Aug 7, 2016 | 11:03 PM
DaveW68's Avatar
Veteran: Army
2015 S550
Pick up this: http://www.ebay.com/itm/like/121931285706?lpid=82&chn=ps&ul_noapp=true
....then download the Torque Pro app to your phone for $4.95. You can do lots of stuff with it, including clearing CEL's and erasing trouble codes.
Old Aug 8, 2016 | 08:23 AM
Lamont's Avatar
2009 s550 4 matic
I already have it.... doesn't clear the codes for abs and esp
Old Aug 8, 2016 | 10:10 AM
DaveW68's Avatar
Veteran: Army
2015 S550
Have you cleared any other codes and CEL's with it before? It's possible that the app is not reading your car and needs to be set up properly with your phone. You need to read and clear the codes from the key position just before engine start....with all of the idiot lights on. Also make sure you have a proper Bluetooth connection and that your phone isn't connected to anything else.
If you're doing it properly and the codes don't go away, then there may still be an issue with the ABS and ESP.
I know that there are some codes that can only be read with STAR. If the Torque app connects properly and you're doing it properly....and still cannot clear the codes, then you'll have to find somebody with STAR to check it out.
