Weird Noise coming from engine bay
hello. It is starting to get a little colder here in Texas and I have recently noticed a squeaking noise. I replaced 2 pulleys and the camshaft magnets but still getting a noise. A new noise has recently came along and I took a video. Please leave some feed back to what you may think it is so I can do some research. Thanks.
https://vimeo.com/195250668
Does the noise change with RPMs? If yes, i'd double check all the idler / tensioner pulley bearings. Sounds like you have replaced some already. Removing the belt as suggested by Paul above will also eliminate any idler/accessory issues.
If the sound does not change with RPMs, it might be the secondary cold air pump. The pump should shut off after a couple of minutes though.
Do you have any CELs? Some 2007 550 engines had some timing chain idler wear issues.
