Steering column just stopped going in n out?
Just went to carwash, lifted the steering wheel up a bit with the switch, got back in the car and now it doesnt go up or down. does come in and out. any reset? or am i headed back to the dealer?
Have someone pull fault codes using MB DAS, motor/shaft “may” need replacement best case scenario may simply need to normalized (taught in) using MB DAS.
shoot would that even trigger a fault? Car still has cpo warty hopefully covered.
Is it all the way up? If you move the switch do you hear any attempt to move at all?
They regularly jam in the top position, usually you can hit the steering wheel with your hand downward while actuating the switch and it will release. There are software updates for the older cars so they don't stick so tight at the top of the adjustment. The motors do also fail, we replace them all the time under warranty. |
it moves in and out its kinda low but not all the way down, i do hear a click but no movement. any thoughts? Is that covered under cpo?
I believe it's covered under CPO, take it in and see. It should be.
Originally Posted by 1bad540
(Post 7048285)
I just had mine replaced. $2500 covered under third party warranty.
(Post 7048285)
Had the problem on my '14 ML350. Dealer "fixed" it but it happened again. I posted here about the problem and got this response. Now it's working again.
https://mbworld.org/forums/general-m...t-failure.html |
Originally Posted by DaveW68
(Post 7048773)
My wife says that about me sometimes. I understand your frustration.
Originally Posted by pjw1967
(Post 7048827)
Originally Posted by The Thomas J
(Post 7048579)
I find it funny how going through a carwash basically makes the car dash light up like a casino in Vegas.
Originally Posted by kn51
(Post 7049507)
Originally Posted by ItalianJoe1
(Post 7049386)
They must have replaced the whole column. There is a repair kit for some models that is just the drive or motor, and it's not nearly that expensive.
so tried the in and out a few times and still nothing!! I hear the relay click but no movement. Ill update as im dropping off the car in the morning.
dropped off the car, looks like its the motor in the column. Report back after fix. looks like cpo is covering too.
so wasnt the motor there saying now needs a whole column at 3k not covered under my cpo. what a pos. looks like the alpina is closer than i thought.
Wow, I'm curious why it is not covered, any clarity?
(Post 7052964)
I'm curious why the entire column needs to be replaced. Is the original unit prone to failure? |
No idea serves me right for buying an over priced short warty thru benz. They said they changed the motor and column still doesnt move, so nxt step is the whole column? Im sure my indy would have fixed it in 1 hour... w no parts needed. Now I have to fight w benz no way im paying 3k to fix that. ill trade the car and eat the 3 that way.
so benz goodwilled the repair thru my cpo... lets see hopefully get it back today. there going to scam me for an alignment too while its there,
(Post 7056894)
(Post 7057782)
The alignment will be $2900.
