W221 Retrofits
Old 03-13-2017, 06:15 AM
Tarek Fahmy's Avatar
W221 / W211 / W202
W221 Retrofits
I know these questions might be repeated, but I need to know what options I can add to my W221 S300 2008, e.g can I add the below options as a retrofit:
1- Seat Memory
2- Key-less Entree With Engine Start/Stop
3- Blind Spots Assist
4- Soft Close Doors
5- Auto Trunk Lid Close
Yes, it sounds crazy, but I love my vehicle & I don't want to change it.
Appreciate your support
Old 03-14-2017, 10:58 AM
DaveW68's Avatar
Location: Land of Political Criminals and Urban Shootings
2015 S550
You'd likely spend more to retrofit those items than your car is worth. You'd be better served buying another car that already has those options.
Old 03-14-2017, 11:59 AM
Mike5215's Avatar
2016 C300
Wow, different markets I guess. All of those but keyless go were standard on US models. You'd literally have to tear the car apart to install all that stuff. Dave's right. Buy a 2010+.
Old 03-15-2017, 12:41 PM
Jason B's Avatar
W140 Mercedes S350, W221 S550 sport
The only thing I'd like to add is blind spot assist. Once you have it, or has a loaner like I did for a long trip, it's hard to go back,. But I'll will put it into distant memory as I now have a GL with it built in for long trips. BUT, it would still be cool if there was an easy way to add it.
Old 03-15-2017, 02:06 PM
bensitto's Avatar
S550, R350, GL550, ML63 AMG
All of that is possible if you have the $$
MBenzNL - Steve Krabbenborg
http://www.mercedesforum.nl/mbenznl/
Good luck.
The following 2 users liked this post by bensitto:
Nuru (03-27-2017), Tarek Fahmy (03-19-2017)
Old 03-27-2017, 12:44 PM
raymond g-'s Avatar
99 E320
Tarek,
I believe that the MB WIS service manual has a list of commonly retrofitted
items which are relatively do-able at the dealer. If you don't have access to
this, PM me your VIN and I'll see if I can pull anything up for your model. r-
Old 03-27-2017, 02:45 PM
Nuru's Avatar
S350 BT 4MATIC
Retrofitting of Major options like Factory NAV, Blindspot assist, lane keeping assists are kinda tough to get a US dealership to do. Most probably won't, especially with the safety options as they can get into a huge amount of trouble (liability), if something goes wrong with the enabling a non-factory orginated option on a car, and that is identified as helping cause an accident.
Old 03-29-2017, 02:37 AM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
US Dealers will not even install Distronic. Too much litigation in the US, hence disabling "tunnel mode" on HVAC and rain-close on sunroof.
Quick Reply: W221 Retrofits
