Location of Fuse Box in the Trunk? 07
Old Aug 21, 2017 | 06:02 PM
gotthebenz?'s Avatar
04 SL600
I have an 07 W221. I've torn apart the trunk of my car and can't seem to find the rear fuse box. Anyone know the location/how to access it? I think I've blown a fuse for my Comand, (it seems there are a few different ones to check in the trunk for it). When I was recently installing my stereo integration kit I did test the power and ground wires first, they were showing correct output, but my guess is that they must've crossed and blown the fuse when I was putting things back as they have no power now. I really appreciate your help!
Old Aug 21, 2017 | 06:24 PM
DaveW68's Avatar
Veteran: Army
2015 S550
It's behind the panel behind the back seat....next to the rear accessory battery. To get to it, remove the screws holding the bottom trunk cover where you can attach the trunk net. This will allow you to pull that rear panel out (with a little bit of work) and have access to the fuse box. While you're in there, if you still have the original accessory battery, you might as well replace it with an H8 AGM battery.
Old Aug 21, 2017 | 08:32 PM
YCHU's Avatar
2008 S550, 2004 G500, 2020 Cayenne
I have an 08, and I can get to fuse box from inside of the car.
Just pull down the armrest on the rear seat and take out the plastic cover.
Old Apr 18, 2018 | 10:56 PM
Gordon Cooke's Avatar
2008 CL550 Graphite Designo, 2005 e320 4matic Wagon, 2001 Mercedes S430 (SOLD) , 1988 Porsche 944 S
trunk fuse box 2008 CL550 W216
This is 100% the way to do it. I opened it up from the trunk and then realized I couldnt actually take OUT the fuses. You pull down the armrest, open storage area, and then pop off the plastic cover at the bottom.
