w221 oil usage , worn engine or bad technicians
W203
Hello. Ive bought w221 on 240k miles on the clock . First trip i had was like 2k miles . in the middle of my way back home yellow light come to add some oil . i did add 5w30 and after another 1000km lamp came back. total i added like 3Litres for 3000km. came back and serviced the car from A to z. car runs very well . when idle no smoke coming from exhaust . when driving hardly and kick down a little black/grey smoke comes out . Turbo has no moves( donno how is the word) . its basicly new ( 20k miles droven with it ) . car runs very good but where the oil came ??? nothing shows on star , no check engine ? when changing oils i have replaced 2 orange seals around the turbo charger , they were broken . the only mistake star gives is 2644 something about the MAF sensor i think . nothing else . car puls out very good . and here comes the question , spoke to 3 technicians not in official dealreship but others , all they think engine worn out . pistons /rings ... something like that . but until i open the engine and see nothing is sure . fixing this would cost me around 2k gbp and am not going to do it . before i sell the car for spares repairs i eant to be sure im not making mistake . please help me . what are the symptoms if pistons are worn out ? also i have a little oil in the left air filter box . engine is so quiet and running so good that i cant belive it can be worn . turbo is good , what else left ?
you replaced the turbo intake (orange) seals so this is good.
next check carefully under car on the back of the engine if there is a leak through the overflow hole. if there is oil coming out of there it is you oil cooler seals- very common on the om642 motor. oil will either drip on the ground or on the exhaust and will burn without a trace.
if no oil on the back of the engine remove Y- shaped intake and run the engine with the turbo impeller visible. have an assistant pump the throttle in quick succession and observe if the impeller spills oil in a centrifugal manner. if it does it is your oil seals despite the fact that turbo shaft has no play (luft).
if no oil coming out of the shaft have a static compression test performed on cylinders to determine piston seals and valve guides condition. this is somewhat not trivial and is usually done by a dedicated diesel engine shop.
good luck
good luck
W203
good luck
good luck
mate turbo has no luft . attaching photo of under engine
W203
right side clean
left side
left side
no bracket in that circle thing , the hose has no bracket to stick it hard .
new seals
left side
one of the photos in oil on the ground , am not sure if it was from my car . was in the mall parking and i had just parked in the place of other car .but there is oil under the engine cover as u can see . and engine itself is littlemoily from the left side . i just dont understand how oil is going to the exhaust and car burns it ? this part i dont understand ? oil going through where ? have a look at the nest photos . right side around right filter box is clear . left side is very oilish .
