2012 S350 Diesel low rpm at idle
Old Apr 5, 2018 | 11:39 AM
steaua1986's Avatar
GL350
Hi,
I have an issue on my 2012 S350 ... engine at idle stays at 500rpm about 90% of times and 700 the other 10%. It doesn't fluctuates up and down, the short time it is at 700 it stays like that for 10-15 minutes (obviously I'm driving during this time so at stop lights is 700) and then drops to 500rpm. Hooked up the scanner (Xentry/DAS) and no codes listed. I had a complete clean of the intake and an EGR valve replaced when I took the car in for the infamous oil filter gasket leak replacement. New fuel filter as well.
Has anybody experienced this? Any ideas what else I could try?
Thanks.
Old Dec 17, 2020 | 02:31 AM
Devis Lula's Avatar
mercedes s350 bluetec 2013
Originally Posted by steaua1986
Hi,
Thanks.
have you ever find out anything about this? Im having the same problem with my s350 no codes or anything like that...
Old Dec 17, 2020 | 12:38 PM
steaua1986's Avatar
GL350
Unfortunately not. I even took it to a Mercedes dealer and was willing to pay the inflated diagnostic fee ... even them were not able to find out the problem.
Old Dec 18, 2020 | 12:14 AM
artim808's Avatar
2012 S350 Bluetec 4MATIC; 2011 ML350; 2005 C230k;
Why you think this is a problem? Did you check actual RPM with scanner? It should be around 580 RPM idle. Only during DPF regen, or when AC is on and it is hot outside the idle RPM jump to 750.
Or also if the battery is low then idle RPM jumps to 750 so alternator can charge the battery.
Old Aug 27, 2021 | 11:39 PM
steaua1986's Avatar
GL350
I called the dealer and asked and they told me it is too low. It should be 700 and jump to 900 in the cases you listed. I also have the same engine on a GL350 and rpm is around 700 (and high side 900) so that confirms it.
Old Aug 28, 2021 | 10:56 AM
Minh's Avatar
S350 2008
For gasoline engine, you can adjust idle RPM with Xentry/DAS under Me9.7 adaptation data.
