Hissing sound after engine is switched off
Old Apr 17, 2018 | 10:18 PM
Yomi A's Avatar
S550, GL550
My S550 2007 still drives like a breeze. I recently did a paint job on it looks brand new... 3 months ago it started giving a loud hissing sound around the front right wheel. I read on this forum that it is normal. But having owned the car for over 10 years this is surely a new development. Today, after the hissing sound, I went to my office came back 8hours later and the rear of the car was virtually sitting on the Tyres. I switched on the engine and was glad to see the rear go up to the normal level. This is a first time occurrence. I drove home, switched off the engine, it hissed and appears to be stable, an hour later. I believe by the time I go check in the morning, the rear of the car, may be on the Tyres again. What can be going on here please? Do I need to change my pump? Could it be leaking? I need to add that I changed my rear shocks about 4 months ago and all is well. But the hissing in the front right side, started a few weeks after. Please help! Anyone?
Old Apr 18, 2018 | 10:48 AM
konigstiger's Avatar
'71 Pinto
Check for leaks (see attachment), no leaks have someone pull fault codes using MB DAS (diagnostics), no fault codes may be internal leak in strut consider replacing. Cost effective alternatives to new OEM: https://www.arnottindustries.com/ & http://www.rebuildmastertech.com/
File Type: pdf
Old Apr 18, 2018 | 04:29 PM
Yomi A's Avatar
S550, GL550
Thank you so much. I will check for leaks as advised
