Hiw common are pano roof issues
Old Aug 27, 2018 | 10:56 AM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
Just wondering how common panoramic roof problems are (particularly with skipping gear drives). I the 221. I have personally experienced it. How many others?
Old Aug 27, 2018 | 03:12 PM
dlafever's Avatar
'15 S550, '10 E350 P1/P2, '02 ML320
Mine is working fine, 140k miles and 10 years on the car.
Old Aug 27, 2018 | 05:59 PM
S70Houston's Avatar
2018 GLC300 4Matic; 2008 ML550 4Matic; 2004 C320
So far no issues, 2007 with 144K Miles.
Old Aug 29, 2018 | 12:21 PM
kn51's Avatar
2007 S600
I have. Started the click. Was probably due to the bracket bending or whatever. Funny thing is the motor is a Webasto part (which you'll find in a Ford or something). $1000 repair at the dealership. Thank you warranty.
Car probably had 35K miles on it at the time. Funny thing is how much it ticked me off. Ah, nice weather for a change...let me finally use the roof....Click click click.
Old Aug 30, 2018 | 10:20 AM
lionsfan54's Avatar
Mercedes Benz S600
In general, I loathe them because in every vehicle I've had with them (S600, Cadillac) they all generate squeaks and rattles. I jokingly refer to pano roofs as "rattle factories". There's just so much up there that can move and flex they noises never stop. Although I am pretty picky about noises.
Currently battling a nasty one on the "cross bar" portion of the roof of my car right now actually!
Old Aug 30, 2018 | 04:35 PM
mrmotoguzzi00's Avatar
Used to pop a little pulling out of the driveway on an angle. No i just go slower.. no popping... and try to go pullout straight.... the whole car probably likes that I don't torsion-ally load it all the time as well
Old Sep 3, 2018 | 09:47 PM
Polar Bear's Avatar
I have no idea what happened to my grammar in the first post- I’m really not stupid !
Since the W221 S600 came standard with all options sans a wheel upgrade or iPod integration, the panoramic roof was standard. I honestly wanted it and like it, but the front motor started slipping the worm gear at less than 36k. I try to DIY most things and probably have more knowledge on Mercedes-Benz than the average driver, so I dropped the headliner on the driver side and placed a washer where the motor housing expands causing the slipping and had no issue. But of course the passenger side motor got jealous so I am going to fix that one as well. It is well known Mercedes-Benz reuses parts from other models but I was somewhat surprised when I discovered the motor was from a W203. I didn’t have to replace it, but will say if you ever hear the grinding noise, immediately have the roof lubricated with the specified grease and do not use it if it continues grinding. Yes, on a nice day you can “assist” it closed but you will wear out parts that are significantly more difficult to change. Fortunately I learned about this and did not encounter it. Mine is still at 39,903 miles. I haven’t got to enjoy it this year as I had hoped but there is always autum and spring coming up. I just have to decide between it and the Grand National!
