MBWorld.org Forums
MBWorld.org Forums (https://mbworld.org/forums/)
-   S-Class (W221) (https://mbworld.org/forums/s-class-w221-74/)
-   -   Can Star C3 be used to update car's firmware off-line? (https://mbworld.org/forums/s-class-w221/736185-can-star-c3-used-update-cars-firmware-off-line.html)
George993 Feb 17, 2019 10:09 PM
Hi, has anyone used Star C3 to update car's firmware without Internet/Mercedes connection? For example to flash/update door control software/firmware/code?
It did not work for me (error about failing to connect to a socket), and I don't know if I was doing something wrong or using some limited functionality Star s/w version and I should just upgrade to a different Star software?
When I look at new Star C3 systems, all of them come with the following description of capabilities in Chinglish:
"Coding and programming
All electric system Diagnostic (Does not include flash code)"
What does it mean in English? Does it mean that module programming is supported? Or does it mean that there is no ability to update the car's software/firmware/code?
thanks!!!!
EasyPhil Feb 18, 2019 01:55 PM
Yes you most certainly can but you have to have a correctly configured system, check out *******.com for more information(you have your work cut out for you). I've updated door modules, central display, radar, command, keyless go, etc.
alana alvarez Feb 18, 2019 04:20 PM
Hi do you mind sharing what types of Command updates you have done? I have a CLK 550 2009 and it comes with the 30 pin AUX cable. I purchased the Apple adaptor from 30 pin to the lighting, however it will not play music saying device is not supported. I contacted apple they said the firmware on the command may need updating. I looked at a few posts on the forum talking about a 46/06 update... would that work? Do I need some new codes?
George993 Feb 18, 2019 09:44 PM
Thanks EasyPhil. Another member also confirmed it off-line. So I've spent some time studying it throughout the Internet (and forums here) and while off line programming is possible with C3 it needs 3 things:
1) correct Xentry version
most people are saying to use year 2012, either 7-2012 or 11-2012). It is progressively more difficult to get it working with newer versions until it becomes impossible around 2014-2015, hard to pin point the exact release as there is a lot of conflicting data (some say no off line from 7-2014, but at least one Chinese vendor claims they have it in a very popular 12-2014).
2) correctly configured this version with appropriate off-line keys
3) the actual new file/image to be burned in. Apparently it can be a part of an older Xentry distribution or obtained from *******.com etc
So looks like quite a bit of work may be needed to set those things up, unless it lucks out in a distribution where someone has already automated the setup. Out of curiosity - which Xentry version you know works for this programming? thx
EasyPhil Feb 19, 2019 09:28 AM
You can configure offline programming with a 2015 version of DAS/Xentry but you need the CCF files for your model to do offline programming.
George993 Feb 19, 2019 02:34 PM
ok, thanks
© 2026 MH Sub I, LLC dba Internet Brands
