Remote Key Battery
Old 04-06-2019, 12:15 AM
Palmeroj's Avatar
Mercedes S550 4MATIC
Remote Key Battery
I keep getting the message "Replace Electronic Key Battery" even after putting new batteries in both keys. Anyone with this issue?
So, after posting this, I found the solution in a different forum. Car needs to be started once by removing the push button starter cover then inserting the FOB. After that, replace the push button starter cover and start two times.
Note: After trying that, it didn't work for me.
Thank you.
John
2016 S550 4MATIC
Old 04-06-2019, 12:22 PM
konigstiger's Avatar
Received 4,411 Likes on 3,144 Posts
'71 Pinto
If you have not already done so try cleaning the contacts no difference, try replacing CR2025 battery with CR2032 both are 3V but 32 is a bit thicker.
JJKCMO (11-28-2020)
Old 04-08-2019, 07:00 PM
dweb4's Avatar
S550 4-matic
Yes give the CR2032 a try it worked for me soon as I replaced it message went out.
Old 04-08-2019, 07:23 PM
BenzoPro's Avatar
2016 G550
I used the same CR2032 and i had no issues. ?
Old 04-12-2019, 11:30 AM
Palmeroj's Avatar
Turns out the spare key had a slightly depleted battery. Using a volt meter, I checked the voltage on both keys, one read 3.4 (approx.) but the spare was just below 3.0. Seems this makes enough of a difference. Once I put the 3.4 battery back in the key, the message went away. The spare now has no battery (until I get a CR2032 for it.)
Thanks for all the great suggestions.
Old 04-18-2019, 10:46 AM
JDowney's Avatar
2012 Mercedes-Benz S350 BlueTEC 2013 ML350 BlueTEC
Hi,
I just went to my dealer with both key FOBS. They replaced the batteries for free, and it took less than 5 minutes...
Jeff
Old 04-19-2019, 07:47 AM
Pitek's Avatar
06 MB E350 4Matic Sedan, 08 MB S550 4Matic Sedan
Originally Posted by JDowney
Hi,
Jeff
For free??? At the MB dealership?? This is impossible! Unthread-of. Strange.
JJKCMO (11-28-2020)
Old 04-19-2019, 11:29 PM
Palmeroj's Avatar
No Way!!
Hi,
Jeff
Never heard of “free” at MB dealership. This is one for the Guinness book of records! Where is this dealership? Did they mess up on something and trying to keep you happy?
Anyway, it’s not replacing batteries that’s a problem, it’s getting the car to stop complaining about the batteries being low, even when fresh ones are put in both keys.
JJKCMO (11-28-2020)
Old 04-22-2019, 10:12 AM
GaryBee's Avatar
2011 S550
Thank you,!! My fob would do everything except start the car. I took your advice and replaced the 2025 with the heaver 2032. PROBLEM SOLVED!!
Old 11-28-2020, 09:35 PM
JJKCMO's Avatar
Exige S | V70R | CTS-V wagon | JKUR | 13 S65 (Mocha/Armagnac)
Bumping this because the 2032 battery swap worked on both of our keys - even new standard batteries got the "replace battery soon" message.
Quick Reply: Remote Key Battery
