S600 AC problem
If it has enough 134A in it you will get to replace the compressor.
It comes out the top after pulling the radiator and rad fan. If everything is original this is your opportunity to give it a new SERP belt, all the belt idlers and tensioner. How old is the water pump? Easy replacement now. If the radiator has never been replaced.... look real closely at the plastic seam that intake air passes through while finding its way to the air filters. Radiator likes to crack there for a leak that makes coolant injection to the intake air. How many miles? The alternator will live 100-120K miles. It also comes out the top.
With enough practice I got to be able to get the radiator and fan out pretty quickly. Due to doing aforementioned replacements mostly one at a time... all within 15,000 miles. Hindsight being all that is.
