W221 TRUNK CLOSE BUTTON SWITCH HELP
Old Dec 8, 2019 | 10:02 PM
azontodance's Avatar
Mercedes Benz S550
2008 S550,trunk opens from door panel, from remote control, from trunk button but doesn't goes up automatically, needs to be open by hand and same way to close.
The open and close red button doesn't illuminate.
It was working fine before until the day i left the trunk opened for about an 40minutes, then the close button didn't illuminate and i pressed, it didn't close the trunk.
Since then, I have been slamming and pulling it manually. I tested the voltage going to the switch, i got 11+ voltage. So I replaced the Trunk lock close button switch, but still didn't illuminate.
Does any one know which fuse controls the close button switch? or is there anything else since i got 11volt from one of the switch wires?
Old Dec 9, 2019 | 09:29 AM
konigstiger's Avatar
'71 Pinto
Pull 147 @ rear SAM for 15 minutes or so with trunk closed in an attempt to reset RTC CU.
Old Dec 9, 2019 | 10:10 PM
Mercedes Benz S550
Thanks man. It says remote trunk closing?
Old Dec 10, 2019 | 07:49 AM
'71 Pinto
Does your data card show code 881 if so, 147 (control unit) is applicable.
Old Dec 12, 2019 | 06:59 PM
Mercedes Benz S550
thank you. Pls I'm a rookie. What do you mean by data card code?
Old Dec 13, 2019 | 08:29 AM
'71 Pinto
VIN?
Old Dec 13, 2019 | 04:15 PM
Mercedes Benz S550
VIN?
WDDNG71X28A194970
Old Dec 13, 2019 | 04:34 PM
'71 Pinto
Vehicle is equipped with 881 remote boot lid closing so pull 147 @ rear SAM for 15 minutes or so with trunk closed in an attempt to reset control unit. No guarantee nevertheless, worth a try.
File Type: pdf
Old Dec 13, 2019 | 07:25 PM
Mercedes Benz S550
my 147 has no fuse connection
Old Dec 14, 2019 | 09:41 AM
'71 Pinto
Odd, check your PM.
Old Jan 10, 2020 | 04:56 PM
Mercedes Benz S550
THANKS TO EVERYONE THAT CONTRIBUTED.. IT WAS THE MODULE THAT GOT CORRODED. I think water got inside
Old Feb 7, 2020 | 09:44 AM
Mercedes Benz S550
So now with the new module, the trunk pulls up, but doesn't go down with the button or remote. I have to pull it down with my hand.
But it pulls up when open with remote or button
Old Feb 9, 2020 | 05:43 PM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
Did you have the dealer install it or do it yourself? It will need to be calibrated using SDS to work properly.
Old Feb 10, 2020 | 06:28 PM
Mercedes Benz S550
sotry, it not a brand new. It a used module from ebay
