Happy to announce that the NTG3 clock/date/time fix I posted last year is official!
Old Jan 11, 2020 | 09:33 PM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
Arrow Happy to announce that the NTG3 clock/date/time fix I posted last year is official!
I am happy to say to say that as of 01/02/2020, Daimler issue a dealer technical document available to all Mercedes-Benz dealers that supersedes the previous TIPS document that was a "workaround" suggesting you visit your local dealer to have your analog clock adjusted when DST began and ended, as well as stating the date listed would never be able to be corrected. As many members on here have downloaded the modified firmware and updated their COMAND units, the TIPS document released on 01/02/2020 now references the exact file that was offered to you last year as a way for the dealers to actually fix the issue and not require return visits when DST began and ended.
For those that may have been a little apprehensive to carryout an "unofficial" update, you will be pleased to know now it is no longer "unofficial!" You can now visit your local Mercedes-Benz dealer and have them perform this for you. I have know knowledge of the costs, if any, is involved, so I highly encourage you to call your Service Advisor and speak to him/her to inquire about potential costs before making an appointment.
This is great news that Daimler did provide this fix and if you do not feel you are technical savvy enough to do it yourself, your dealer can now take care of this for you, and it will only be a one time procedure.
For those already that have performed this procedure themselves, you will be happy to know the ISO file that Daimler is providing to dealers is identical, bit by bit, to the one I released last year, so you are running an official fix for this issue! There is no need to return to the dealer now to have them repeat it as the code is the exact same.
Here is a link to the original post in October 2019 that provides instructions and a link to download the files needed to DIY. It also has a video on how it is carried out to know what to expect when performing the operation.
https://mbworld.org/forums/s-class-w...ml#post7889282
Here is the MD5 values for the ISO I posted last year, and the one Daimler recommends their dealers use to fix the S-Class clock issue - they are identical.
File Type: pdf
Old Jan 12, 2020 | 11:55 AM
BOTUS's Avatar
S500
Nice one,
shame they don't support a tweak to so the comand "not on latest firmware" error goes away ?
Old Jan 12, 2020 | 01:43 PM
Polar Bear's Avatar
Originally Posted by BOTUS
Nice one,
Since it is simply benign, and only people with DAS will be aware of it and the way the releases are referenced by their version number, that one simply has to be incremented at least by .1 or the COMAND will to consider it an upgrade. The same version would report that version was already installed and refuse it, so unless they update other parts of the COMAND OS, we likely will be stuck with it.
Old Jan 12, 2020 | 06:23 PM
megacrazy's Avatar
CLK55 W209, CL63 W216
Nice work. I’ll be upgrading mine soon.
Annoying that the community has to release an update for their crappy software and then they have no issue appropriating it. Ridiculous.
Old Jan 12, 2020 | 10:48 PM
Hatzenbach's Avatar
2009 W221
YOU ARE THE MAN!
Old May 22, 2020 | 06:52 AM
Eduardsil's Avatar
s320L
hello, could someone send me iso file please to update? thanks in advance
Old May 22, 2020 | 09:18 AM
pmercury's Avatar
member
CL
its here iI think
Old May 22, 2020 | 09:23 AM
Eduardsil's Avatar
s320L
its not there, none of the links work! i spent hours looking for that iso file, could someone help me please?
Old May 22, 2020 | 10:55 AM
BOTUS's Avatar
S500
its attached in this thread, you don't need to email anyone... #137
https://mbworld.org/forums/s-class-w...ml#post8025933
Old Jun 11, 2020 | 08:41 PM
DrDoe's Avatar
W212 E350; W166 GLC300; W164 ML550; W164 ML63; W221 S65; W220 S430; Escalade ESV
I did this update. I took a chance as I don't know how to check for corruption file. Things went well until the system shut down and restart. Stared at the black screen for a while and I was nervous. Finally decided to power cycling the system and it came up normally. Updated the time and the analog hands moved to the correct time. Thank you.
Old Jun 12, 2020 | 11:16 AM
BOTUS's Avatar
S500
always do any map or clock update with the car running !!!!
they eat 37 amps with the key on, and even a brand new AGM 25kg battery can only support that current drain for a few minutes
Old Jun 12, 2020 | 11:23 PM
kbob999's Avatar
'20 X5 M50i; '17 Ram 3500; Golf Cart; Bikes; Scooters
I also just ran the firmware update and it worked perfectly!
The battery was on a 2 amp charger and barely kept up, getting as low as 11.5 volts, but finished just fine.
So happy the clock reads right. Thanks so much!
Old Jun 13, 2020 | 03:02 AM
pmercury's Avatar
member
CL
If anyone wants my CD and the instructions, send me a PM and I’ll mail them to you for the $5 shipping cost.
I only have one so I’ll delete this message once it is claimed. Just want to help others like they have helped me.
pm me the part number I might have a image that will avoid posting
Old Jun 13, 2020 | 04:44 AM
BOTUS's Avatar
S500
that's a huge risk, once these drop below 12.1v anything can happen, as I said they use 37 amps, so of course a 2 amp charger doesn't work. If you turn lights, radio and both blower motors off and put 4 amps in it, it will just stay alive long enough to do a diagnostics test, but never try programme or update like this
as for your car and the other post about the screen cutting out.... you will now have every module on the car reporting the world ended in diagnostics... it will clear but low volts on any Merc are just trouble you don't need to encourage
Old Jun 21, 2020 | 09:09 PM
JezClay's Avatar
2008 s550 4Matic 2012 BMW 328i Convertible 2005 Ford Excursion 6.0 2002 Landrover D2 1996 Ford f150
thanks so much for this as its been driving me mad.... worked like a charm
Old Aug 9, 2022 | 05:14 AM
nigel016's Avatar
CL63 AMG
Hi, I have this issue and when I click the link for the download it is out of date. Can anyone post a revised link please?
Old Aug 9, 2022 | 07:45 AM
BOTUS's Avatar
S500
you found the wrong post - this was an announcement about Merc officially adopting Polar Bear and his chums great work - but there are other developments for a few missing units some mid 2007 / early 2008 units were left out
https://mbworld.org/forums/s-class-w...ml#post8468441
