TELE AID ERROR
2006 mercedes benz s500
TELE AID ERROR
I AM GETTING THE TELEAID MALFUNCTION /TAKE TO REPAIR SHOP INDICATION. I DO NOT HAVE A SUBSCRIPTION NOR DO I WANT ONE. IF I PULL THE FUSE FOR THE TELE AID, WILL THE MESSAGE GO OUT, AND WILL DOING SO AFFECT ANY OTHER SYSTEMS? WHICH FUSE NUMBER AND BOX WOULD THIS BE LOCATED IN? I APPRECIATE ANY HELP. THANKS ,MIKE
You will still get the error. If you want to get rid of the Teleaid system, you can do coding. First you have to remove it from central gateway and if that is not enough, remove it from instrument cluster coding.
