W221/W216 Side view mirror disassembly
Old Feb 22, 2020 | 04:13 PM
COUPCONNOISSEUR's Avatar
2010 CL550
can someone PLEASE help me at getting the sideview mirrors disassembled! i know, before you say watch some videos..ive watched them all and for some reason, the cover on mine just refuses to detach on the mirror facing side on just one corner..ive broken 3 replacement mirror glass already so im beyond furious =(
id also like to provide some info for other w216 owners..the mounts are different on the w221..everything else is the same.
Old Feb 22, 2020 | 04:39 PM
konigstiger's Avatar
'71 Pinto
See attachments.
File Type: pdf
File Type: pdf
Old Feb 22, 2020 | 06:01 PM
2010 CL550
See attachments.
thank you for once again coming through..I’ve been following this procedure and it just will not come apart..
Old Feb 22, 2020 | 09:54 PM
user 58362638's Avatar
I know you've seen videos, but have you seen this one? The video is extremely well done by one of the members.
Old Feb 22, 2020 | 10:30 PM
2010 CL550
https://youtu.be/ET2HGcKeKB0
thank you as well for contributing..yes, ive see this one too, in fact thats what i was trying to do(upgrade the bulb on the bottom) i was only able to get the housing/cover removed on the drivers side after the glass already cracked..same thing happened on the passenger side but the glass cracked before i was even able to get that cover off..anyone have a trick to this without destroying the glass for a 4th time?
Old Feb 23, 2020 | 08:58 AM
'71 Pinto
How about this one...
Old Feb 23, 2020 | 01:45 PM
2010 CL550
these are pictures of the 3 mirrors I’ve pretty much ruined trying to take apart, following all instructions..
unfortunately this procedure is for the old style mirrors on the 09 and before which is different from mine. i watched it anyway just to see if maybe it had something. but i appreciate your help. at this point im going to say that the mirrors on the CL look identical to the S but they are held on differently...
