08 S550 Front end crash. Engine damage?
Old Apr 28, 2020 | 08:31 PM
Lefley16's Avatar
2008 S550 4 Matic
08 S550 Front end crash. No start after repairs.
I bought a black on black 2008 S550 4 matic 90,000km with a clean title.
Crash hit up high and pushed the radiator up against the engine. Engine and transmission mounts broke. Oil pan shattered.
I removed the engine and transmission and looked for any other damage and found nothing. Engine turns by hand.
I put everything in except the exhaust and front end and it will not start. No crank. Tried swapping modules and fuses from another s550 parts car and nothing. I think I hear the fuel pump going and fuel came out when disconnecting the fuel line.
Any ideas?
Old Apr 28, 2020 | 10:12 PM
MBNUT1's Avatar
2010 E350 4Matic
You checked the battery voltage? Also these cars are known to have bad starters.
Old Apr 28, 2020 | 11:04 PM
Lefley16's Avatar
2008 S550 4 Matic
Voltage sits around 11.6. Both batteries are fully charged. I will test the starter next.
Old Apr 28, 2020 | 11:40 PM
EasyPhil's Avatar
2007 S550 4Matic 2013 S550 Base
I don't think that's enough voltage to start the car.
Old Apr 29, 2020 | 12:44 AM
DaleB's Avatar
Veteran: Army
2007 S600
Those two statements are in conflict. 11.6 V is not charged period, let alone fully charged.
Old Apr 29, 2020 | 06:25 AM
amgs63dxb's Avatar
W222, W221, W218, W211
my S basically dies if the dash shows 11 V (turning the ignition causes total blackout)
Old Apr 29, 2020 | 09:01 AM
DaleB's Avatar
Veteran: Army
2007 S600
Ah, there's the link I was looking for. https://batteryuniversity.com/learn/...tate_of_charge -- at 11.6 your battery is pretty much fully discharged. It should show at least 12.5 or higher if it's a good battery and is charged. I'd say throw a battery charger on it for a day or two, try to crank it, and see what the voltage is afterward. Even a bad battery will often show 12.5 to 12.7 after charging, until the first time it sees any kind of load.
Old Apr 29, 2020 | 11:04 AM
Lefley16's Avatar
2008 S550 4 Matic
I take both batteries from my other S Class which I daily drive. They read full in my daily. When in my project they are low for some reason.
Old Apr 29, 2020 | 11:05 AM
Lefley16's Avatar
2008 S550 4 Matic
Tried charging over night and half the day. Also tried boosting with another car. Nothing.
The voltage doesn’t change at all after charging.
Old Apr 29, 2020 | 12:54 PM
joseluu's Avatar
W221 S500 2010
Either your meter is faulty or those batteries are bad. You simply cannot have 11.6 V on a good battery after a full charge.
(Or you have a HUGE load present in the car, but it had to be so big that I cannot belive that is the case).
Old Apr 29, 2020 | 08:45 PM
Lefley16's Avatar
2008 S550 4 Matic
Well I use a scanner that tells the voltage. Reads normal on my other cars. I also bought both batteries less than a year ago.
What kind of load could it be?
Old Apr 29, 2020 | 08:48 PM
Lefley16's Avatar
2008 S550 4 Matic
Also I notice I get almost no spark when hooking up the starter battery.
Old Apr 30, 2020 | 04:44 AM
joseluu's Avatar
W221 S500 2010
Just in case, forget the scanner and mesure the voltage with a volt-meter at hte battery posts. I insist a battery cannot have 11.6 V after a full charge.
If you had a load able to make a good battery go to 11.6 I can assure you that you would notice the spark when connecting it, so we can forget about that.
Old Apr 30, 2020 | 04:18 PM
DaleB's Avatar
Veteran: Army
2007 S600
What he said. A $5 (or freebie) Harbor Freight multimeter on the 20V scale will tell you the state of your battery with far more accuracy and reliability than almost any on-board or plug-in monitor.
Old Apr 30, 2020 | 04:41 PM
Lefley16's Avatar
2008 S550 4 Matic
Ok I’ll head out and buy one.
Old May 1, 2020 | 05:50 PM
Lefley16's Avatar
2008 S550 4 Matic
Starter engaged with some booster cables. I put in the starter battery to turn on the dash.
Starter clicked and nothing else new. Voltage went from 12.6 to 12.
Old May 2, 2020 | 02:57 AM
joseluu's Avatar
W221 S500 2010
You cannot assure anything until you install a NEW battery. Booster, charger and whatever will not give you a definitive answer.
Old May 2, 2020 | 04:22 AM
prktkljokr's Avatar
12 C200, 12 C180, 10 Fuso Warrior crew cab, 08 RTV ute, 05 Smart Fortwo cabrio, 09 Smart Fortwo
Have you gone through and checked all the fuses and pre fuses, if it was hit high it may have blown some fuses in the system, for it to break mounts etc it would have been a decent impact.
Old May 2, 2020 | 01:24 PM
Lefley16's Avatar
2008 S550 4 Matic
I have changed almost all the fuses people recommend online. Fuel pump, alternator, etc
Swapped the module beside the starter battery and above the rear trunk battery. Nothing. Swapped the modules from my project into my daily and they worked perfectly.
Ive seen online people get their benzs reset after a crash with a high end scan tool. They have the same issue. Reading no gas, all interior functions work but nothing happens when you try to startup. So maybe that’s it ?
Old May 4, 2020 | 09:08 PM
EasyPhil's Avatar
First off, if you haven't done a Star Diagnostic to rule certain things out, you are just running around in circles. Secondly, if you car has a battery in front and back, both will need to be sufficiently charged to rule certain things out.
Old Jun 29, 2020 | 06:38 PM
Lefley16's Avatar
2008 S550 4 Matic
Hey a little update here. So I’ve got two new batteries plus a new starter. Starter was tested and was actually bad. I got it running using a screw driver and jumping the two connections on the starter. Still won’t start by the key. Yes I know I should have somebody skilled look at it. I’ll get that done here soon.
Old Jul 3, 2020 | 12:20 PM
MBCO's Avatar
2015 SL550 & 2012 S550 4matic
Within DAS, there is a function entitled “engine restart after crash “ I have not used it, but it leads me to believe there is a procedure that the electronic managers on board need in order to say it’s ok for the engine to startup (or not). You should consider buying your own DAS with the project car issues as well as your other MBs that will develop them as time goes by, likely pay for itself in short order. Good luck and keep us posted.
Old Sep 23, 2020 | 04:12 PM
Lefley16's Avatar
2008 S550 4 Matic
I did some resetting / relearn of the transmission on my $300 scan tool and the car started right up and runs really smooth. This was about a month and a half ago.
Right now I’m trying to fix an issue with the interior climate controls not functioning while blower won’t shut off and the engine fan won’t shut off. No matter what I press it stays the same.
Old Sep 23, 2020 | 05:02 PM
MBCO's Avatar
yes there is definitely a problem most likely with a control unit on the console. all those buttons feed a control unit with software and it will tell the fan to speed up slow down turn the air conditioning compressor on off, heat regulation, ETC.. Can your scanner exercise climate control..all systems. If not this is why you need DAS. PM me for a recommendation.
