Pesky oil leak, please help...
Replaced this and the oil separator, still leaks... What am I missing?
Still leaking under these
What does this connector go to?
Is the leak coming from above the centrifuge and dripping onto the centrifuge? Are you 100% confident in the source of the leak?
Other pertinent facts with this issue
1) Engine oil level is appropriate2) I purchased the vehicle in August, it had the leak when I bought it. Unsure if the previous owner wrenched on it to repair and or cause harm.
3) I use blue threadlocker on the bolts. They felt good going in and out, do not think I over torqued, cracking the cover and or head.
4) I cleaned the mating surface of the head before installing the cover. Also cleaned engine bay under the leak, just using Windex and blue paper shop towels.
Also, do you know if the gasket is available on its own? or comes with the cover?
Thanks.
Mine was orange and $15 from dealer. Be careful not to over torque those bolts when you put cover back on.
Also would you have a part number for the gasket? I was told it only comes with the cover...
ensure all in good order oil and water all topped up drive for 10 miles - then rag the thing to death at least once a week for a few miles... it will love you for it - piston rings need exercise, not a nursemaid
