Air system intermittent gasp.
Old Jan 30, 2022 | 09:02 PM
Chief135smitty's Avatar
2009 S550
Is it normal for the air system to occasionally gasp for air? Sound is coming from the front near the tank. Happens after shutdown or when a demand is placed on the system. Trunk opening etc. Thanks.
Old Jan 30, 2022 | 11:06 PM
Senecat's Avatar
1983 Nissan Shltbox
I think it's purging. I don't know for certain, but I think it's the car leveling itself out, balancing system pressures, and so forth after parking it. Mine does the same thing. Never even crossed my mind that it would be a malfunction. I think it's cool.
Old Jan 31, 2022 | 11:33 AM
Minh's Avatar
S350 2008
It's normal, however the air hose connect to air pump is broken and make a gasp.
Old Jan 31, 2022 | 12:27 PM
BOTUS's Avatar
S500
are we muddling up multiple systems here
the trunk closing I doubt has anything to do with the front of the car, does it not use a pump in the boot behind the rear seats?
at the front right near the headlamp is the airmatic suspension system that should be 100% air tight
Old Jan 31, 2022 | 03:03 PM
kevm14's Avatar
04 E55 AMG (totaled), 07 S550 4Matic, 14 E63S
Mine makes the same sound and I don't think anything is broken. I do find it odd because my E55 Airmatic is nearly silent.
Old Jan 31, 2022 | 04:04 PM
BOTUS's Avatar
S500
Quite often I get a big noise for a split second on switch off I think its the AC dumping moisture and it lands on the exhaust near the CAT (which is very hot) - I don't think it the Air suspension
Old Jan 31, 2022 | 04:05 PM
kevm14's Avatar
It's definitely the air suspension. At least my noise is. And probably Senecat's. And probably the OP...
It sounds like a purge.
Old Jan 31, 2022 | 06:44 PM
Senecat's Avatar
1983 Nissan Shltbox
^ yup. Just the car doing it's thing. There are about 700 sensors in these things constantly working to monitor and adjust things. The car self-levels. The system is just venting and equalizing. I think it's awesome. My car is alive even after I kill it.
Old Jan 31, 2022 | 06:46 PM
Senecat's Avatar
1983 Nissan Shltbox
Compressor is on the right, tank is on the left. Noise comes from a tank valve on the left. This thread is a non-issue, and a good heads-up for future reference.
/thread
Old Jan 31, 2022 | 11:19 PM
The Thomas J's Avatar
2010 MB S550, 2017 MB SLC 300
Yes, it's normal.
