S550 starts then dies
Old Feb 24, 2022 | 12:41 PM
06SL500AMG's Avatar
2006 SL500
I'm looking at a 2009 S550 that starts then dies. That's unfortunately all I know about the issue. What're the possibilities even? Fuel pump, ignition switch, battery is what I've come up with so far. Has anyone ever had an issue like this?
Old Feb 24, 2022 | 01:16 PM
MBCO's Avatar
2015 SL550 & 2012 S550 4matic
Your best approach is to scan the car with MB Xentry scanner. Any fault codes for all systems will be identified, current and stored. Your diagnostic work will be done. The work instructions to replace parts is there as well.
Throwing parts at these cars is not the best approach.
Old Feb 24, 2022 | 09:29 PM
Senecat's Avatar
1983 Nissan Shltbox
"Why won't it start" is not a valid question anymore, much less with a Mercedes. Gone are the days of spark, fuel, air. The good news is, modern cars will usually tell you what's wrong with them, so long as you know how to talk to them.
Pull codes.
Old Feb 25, 2022 | 06:27 AM
camplate's Avatar
S550
While I agree with what MBCO and Senecat say, in my case no codes were or are thrown. My car starts fine 95% of the time but if I add gasoline, either a fill up or just a few gallons, it won't start normally. Sometimes it will start and then die, other times crank but no start. The only way it will start is to have one foot on brake and other on gas, press gas down at least half way, sometimes more, and it will eventually start. It will run rough, need to feather the gas, but then will be fine until next fuel stop with a dozen engine stops and starts.
When my car would shut off after it started it was like the engine was still running. No indicators would change on display, I would need to push button to 'turn off' the car before I could try to start again.
The question for 06SL500AMG: how does it run when it does start, and how long?
Old Sep 1, 2025 | 02:51 AM
JJRW220AMG's Avatar
W220S430 W140S3204MATIC W211E320
Crankshaft Position Sensor
Old Sep 1, 2025 | 06:41 AM
camplate's Avatar
S550
I cannot say what was fixed but this wasn't it. I owned the car for a year and something was replaced, twice wrongly, and didn't have any trouble with starting since.
Old Sep 2, 2025 | 07:50 AM
mcb66's Avatar
clk320
I went from staring and dying, to eventually no start at all. I changed fuel filter, fuel pump and the starter to no avail. Finally I changed the fuel pump relay under the lower panel of the compartment between the rear seats. Cured it! I can't say that it will fix this, but I can say that it is a $12.00 dollar part. One of the cheapest repairs that you will ever make on a Merc.
Old Sep 2, 2025 | 10:17 AM
BOTUS's Avatar
S500
Originally Posted by mcb66
I went from staring and dying, to eventually no start at all..
starting and dying straight away is usually a sign of no / very low fuel pressure
