W221 lower control arms
Currently I drive: 2007 S550 and 2009 ML350
Hello! I have replaced the lower control arms on my 07 S550 a couple of years ago. And I still have the old parts (nice and clean). Is there any use of them for anyone? Or should I just put in the a dumpster?
Rebuild them and keep as spares.
The following 3 users liked this post by Senecat:
which - these are both lower arms (as in, at the bottom of the steering knuckle) the black steel track control arms or the aluminium castor control arms
the steel ones you can rescue the boot on the outer ball joint and post to someone fortunate enough to have had the Mercedes dealer make my day trick - where the shop's stab them with a screw driver to get a nice earner
the aluminium ones can have the front bush replaced, but its not that pricey anyway
aluminum - unsprung weight, easier to make, cheaper
steel - better able to take abuse from the tank above it, kerbing incidents from great drivers
Pasha Mercedes (08-22-2022)
120 aluminum - castor control (maintains the back and forth forces like braking, named after the angle it keeps aka castors on a shopping trolley - helps the wheel go in a straight line)
70 steel - track control (side to side - width - as in track (like a train track)
Pasha Mercedes (11-15-2022)
there are different arms depending upon the model
airtragic
ABC
4x4
I think the track control arms are all steel - but there's a passion on this forum to use appalling naming conventions - I try to sway opinion but the ARB seems get them all bitter and twisted
airtragic
ABC
4x4
04 E55 AMG (totaled), 07 S550 4Matic, 14 E63S
I swear I tested mine with a magnet and came to the conclusion that they were not steel....and I thought I saw listings for silver (presumably Al) and black (presumably painted steel). That just seems weird.
The forward arm is aluminum as it only carries tension forces so aluminum is strong enough. The reason for using aluminum on all parts where it is possible is to minimize the weight of the suspension parts. More weight means lower natural frequency that hurts the ability for the wheel to maintain road contact on rough road surfaces.
Syntax26 (07-08-2023)
