2007 S550
Old Nov 1, 2022 | 04:53 AM
IGGSTER's Avatar
2007 S550
2007 S550
I was driving about 80 MPH on the freeway when my engine shut off. I had the music full volume so I did not hear if there was any noises before it shut off. There was no check engine light. After it shut off, it would not start up again. I plugged in an OBD II scanner and there was 3 codes:
- fuel level sensor 'a'- fuel level sensor 'b'- low voltageI replaced the battery in the trunk, and am replacing the battery under the hood as well. What do I do about fuel level sensor?
Old Nov 1, 2022 | 02:15 PM
BOTUS's Avatar
S500
a few people have had to play with the fuel pump / level sensor - search works quite well on this forum
Old Nov 1, 2022 | 07:50 PM
IGGSTER's Avatar
2007 S550
Also, does anyone know if it's okay to use a different battery for the "auxiliary battery" (located under the hood / engine compartment) Group Size: 51R, CCA: 410.
(link to see actual battery below)
https://www.autozone.com/batteries-s...E&gclsrc=aw.ds
