M276 engine startup noise - Check valves already installed
Old Nov 3, 2022 | 10:50 AM
klingsor's Avatar
S350
I have a 2013 S350 (M276 gasoline engine) that started producing slight engine noise at startup a few months ago. The noise level has increased recently. Also, a message appeared saying I should top off the engine oil which took 1L of additional oil to top it off.
I'm aware of bulletin LI05.10-P-056435 that addresses this issue by installing check valves and chain tensioners. However, the tech at the dealership says my engine has the check valves installed already and he thinks that the driver's side intake camshaft adjuster went bad and he thinks I should change both adjusters and tensioners on the driver's side to solve the issue. I asked him if he thinks the check valve is also bad, and he said it's unlikely.
He tried to push me to change all four adjusters on both sides but at $1k a piece I don't see why I should pay for something that is not broken. What do you guys think?
Old Nov 3, 2022 | 01:23 PM
chassis's Avatar
2017 GLE350 4MATIC
What is your view? Have you spend time diagnosing this yourself?
Changing one side at a time seems reasonable, if you agree with the shop’s diagnosis.
Old Nov 4, 2022 | 06:47 AM
doni01's Avatar
2013 S550 4MATIC
That could be a possibility along with the tensioners but as far as I know when the cam adjusters fail, you do get a check engine light as well so I am thinking it may be just the Tensioners that need replacing. Any way you can put up a video of the rattle?
