water leak under intake
Old Nov 17, 2022 | 04:00 PM
thmterry's Avatar
2012 S550
2012 S550, I have a bad water leak coming out back of motor where a clip in type heater hose pushes into a plastic housing that is bolted to back of left cylinder head or block and then goes to some type of motor before heater control valve.( It is to tight to get good pictures), It fills the front of the intake manifold pan with coolant also. Do I have to remove intake to get to these hoses or plastic housing , I think the plastic housing maybe cracked? My dealer is worthless and can't find a picture of that area.
This is the heater hose the clips into plastic housing
This area fills up with coolant also
Old Nov 18, 2022 | 06:34 AM
Minh's Avatar
S350 2008
No, you don't need to remove intake manifold yo get access to the hose. Just remove ECU, MAF to get more room then you can even remove heater control valve by two T30 screws.
Old Sep 28, 2023 | 05:46 PM
julian2.0's Avatar
2013 cls550
Did you find out what it was? I’m having the same problem with a leak on the heater core outlet housing
