AIRMATIC
AIRMATIC
My 2010 S-550 indicates Malfunction-"The capability of the AIRMATIC system is restricted."
Anyone have a similar problem? Any input on what may be causing the problem?
check if the fuse has popped - its a big orange 40 amp one under the bonnet inside the SAM casing (need to unscrew the 4 bolts to get the lid off )
if its gone, likely an air leak and or a seized level sensor and the system is trying too hard to keep it pumped up - its all normal
Senecat (12-09-2022)
