2011 Mercedes S400
Old Jul 10, 2023 | 06:09 PM
glenemoore's Avatar
2011 Mercedes S400
Angry 2011 Mercedes S400
Command console is dark as well as the CD player. I have disconnected the battery and reset, pushed the ON button for 1 minute, pressed the eject button for 1 minute, checked all the fuses.....still blank.....help!
Old Jul 10, 2023 | 07:04 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W221 forum...
Old Jul 10, 2023 | 07:19 PM
Shadly1's Avatar
2007 S550
Give some focus to fuse F51 in the front SAM in the engine bay. It's for COMAND Display. Should be 5A. Check voltage with the ignition on, check continuity through the fuse and check for corrosion.
If that doesn't work, check F99 in the left dash and F122 in the rear SAM,
Old Jul 10, 2023 | 08:26 PM
glenemoore's Avatar
2011 Mercedes S400
all fuses referenced are good to go but problem still exists.
Old Jul 10, 2023 | 08:49 PM
Shadly1's Avatar
2007 S550
The only other thing that comes to mind is the connector at the back of the COMAND unit. It's pretty easy to remove but a big waste of time if that's not the culprit. It would get you into the back of the unit for circuit tracing though.
