Identifying this particular pulley
Old Sep 23, 2023 | 04:45 PM
rom_s550's Avatar
S550
Edit: figured it out- it’s called a drive accessory belt. Part 611-234-01-93
Greetings,
I am trying to figure this particular pulley that I think is positioned near the power steering, but doesn’t appear to be power steering on this 2008 s550 4matic. The serpentine belt unfortunately snapped and damaged some idler pulleys so I am trying to replace them.
The one in question is the picture below.
I looked at some diagrams that say it’s the power steering location, but it clearly looks like a regular pulley. So I’m a bit confused on what I should look for on replacing: is this just a regular pulley or the power steering? Also a part number would help if I can just replace that pulley. Thanks!
Old Sep 25, 2023 | 03:30 PM
kevm14's Avatar
04 E55 AMG (totaled), 07 S550 4Matic, 14 E63S
I'd order something like the Continental ADK0012P kit which includes the belt, the tensioner and two pulleys. I don't think the belt failing caused the pulley to fail - the opposite. Replace everything.
Old Sep 26, 2023 | 05:24 PM
EasyPhil's Avatar
2007 S550 4Matic 2013 S550 Base
You should also replace that AC pulley as well.
Old Sep 28, 2023 | 10:33 AM
kevm14's Avatar
Yeah I did the whole belt/pulley kit chasing an accessory noise before learning it was the A/C pulley. Not that difficult but sourcing the correct diameter pulley is difficult. The one I ended up with was an eBay special and had a slightly larger diameter (so compressor spins slower). Haven't noticed any ill effects though. These cars have quite large A/C systems so there is probably capacity to spare (which would really only impact idle conditions).
Old Sep 29, 2023 | 06:48 AM
rom_s550's Avatar
S550
Any torque specs for the idler pulley bolts?
Old Sep 29, 2023 | 05:04 PM
EasyPhil's Avatar
35 Nm
Old Oct 2, 2023 | 08:54 AM
BOTUS's Avatar
S500
didn't really put hat in the ring as couldn't get your photos... but found and labeled this today
only oddity is the AC seem lower than I thought and I guessed at the water pump....
