Third brake light error
Old Sep 24, 2023 | 05:45 PM
christianshea's Avatar
S550 2009
Hi everyone, S550 2009. Third brake light error in the dashboard. The third brake light goes on for a few seconds then off. Then error message appears. I checked the 17/1 ground, cleaned it and it was already fine. I could not find rear sam module in my trunk. I suspect a bad relay but I don’t know where it is.
Fuse and relay box in rear center arm rest
Right side trunk
Please help.
Old Sep 25, 2023 | 04:33 AM
BOTUS's Avatar
S500
your top photo shows the SRB with the white part number sticker 221 900 3001 (this is all the relays and fuses - accessed via the rear seat arm rest area) and the rear SAM that clips vertically to it is sitting behind the aluminum bit
its probably failure of the light unit - the SRB and relays are quite durable
if you want to break things and get the SAM out, the black metal H frame has to come out - try not to cut the loom in half at the back of the boot when you refit it ....
