eis/key fob or accessory battery ?
An alternate option would be to leave the switch alone and buy a Keyless Go ignition button. Then you'll never have to turn your ignition cylinder.
https://www.fcpeuro.com/products/mer...mer-2215450714
No takeover from old the ignition switch module possible here
only way is as below
Now if you have Xentry you can borrow a Green/Blue/whatever key (color changes by year) they charge a little fee
then adapt
risk is great as it might be key related also (only xentry will tell)
then, to upgrade from non keyless go to keyless go is just a matter of adding and coding a used keyless go module from ebay
with xentry also no green/blue key required
