Aux plug connect to?
Old Apr 10, 2024 | 12:59 PM
clb0099's Avatar
‘16 Mercedes GLE450 amg,’15 Mercedes gla, coupe,’07 Mercedes w221,’12 Audi A
Hello,
I am installing the oem aux panel inside the gloved and need to know where the plug goes ? Does it going in the main harness?
Old Apr 10, 2024 | 01:36 PM
BOTUS's Avatar
S500
you don't have facelift comand ? is it meant to fit
they did three
early cars - nothing - but you can add stuff to the back of the command - https://mbworld.org/forums/s-class-w...ries-work.html
2007 min facelift - these came with RCA phono plugs in the glove box
2010 later car later comand unit - with aux in idea using a propitiatory merc plug in the glove box
Old Apr 10, 2024 | 07:02 PM
clb0099's Avatar
Botus,
I bought a glovebox that has the rca plugs inside of it. I am asking where the plug from the rca goes to the command.. The second picture is of the plug coming from the rca plugs … anyone know where this plugs into on the main plug to the command?
Old Apr 11, 2024 | 05:45 AM
BOTUS's Avatar
S500
check the link on my original reply.... confident that will be a struggle to reach
Old Apr 13, 2024 | 11:07 PM
clb0099's Avatar
Botus,
I was able to buy the cable I needed to retrofit oem aux jack inputs in the glovebox . Once I get the cable I will be installing a 2024 android radio I bought. Also updating the dashboard trim to the w222 style. Hopefully I have pictures soon. What I like about the android radio is that I can go back to oem screen and still adjust the clock and other options.
Old Apr 14, 2024 | 08:17 AM
clb0099's Avatar
Hello,
The aux cable I bought from Mercedes has 5 pins at the end of it. My guess is that the 3 pins (circled in red ) together are for the L Audio /R Audio and ground. The other 2 pins (circled in black) are for video and ground. I can’t find any directions. This cable connects to the aux inputs in the glovebox. Anyone know?
