Fault code b1039
Old Jul 9, 2024 | 12:40 PM
Ibyellow's Avatar
W221 S Class 320L CDi 2006
Fault code b1039
I'm using the carly app and have manage to get down to my last 5 fault codes.
2 are for tyre pressure. that i dont have attached so ignoring.
1 is the reverse camera that I don't know how to calibrate so ignoring.
1 is normalising of head restraint b1063. Will work this out at some point.
Final one is code b1039. Attached image. But not a clue what it really means. No problems with transmission at all.
Old Jul 9, 2024 | 07:32 PM
Ultrakla$$ic's Avatar
Benz w221 s550
If you aren't having any problems with the trans and if I'm reading that pic correctly it stating a possible CAN communication issue that's seemingly trans related then I'd clear that code and see if it comes back. If it does you may need a scanner that gives a more indepth revelation on the issue. Not familiar with the "Carly" app. Sorry.
