2012 S65 AMG Steering Column Adjsuter Issue - Help!
Old Nov 25, 2024 | 04:38 PM
pshonubi's Avatar
2007 W221 S600, 2008 W211 E550, 2007 Mercedes Benz SL550, 2007 Infiniti QX56, 2000 BMW 328i
Hi Guys,
I discovered my steering wheel will not tilt or telescope and I have no heated steering wheel either. The only odd thing I noticed is that the Stalk that controls the adjustment and heated steering wheel doesn't light up when I twist it. I checked under the kick panel and i see that both motors on the steering are securely connected and everything looks factory.
I have tried to search if there's a fuse that controls it without any success. Any help or guidance would go a long way.
Thanks a lot everyone.
Quick Edit:
I also noticed both rear window privacy shades don't work, both windows go down and come up and the rear screen blinds work too. Any insights would be really appreciated.
Last edited by pshonubi; Nov 25, 2024 at 04:44 PM. Reason: I remembered a few more things i wanted to add
Old Nov 25, 2024 | 07:51 PM
doni01's Avatar
2013 S550 4MATIC
Has the car been driven or sitting? When the battery goes down on these cars it does all crazy things. When my battery was low, the rear window screens wouldn't work either. Once charged up, everything became operational. If that's not it, then you will have to start looking at fuses ...
Old Nov 29, 2024 | 09:34 AM
Olufemi Shonubi's Avatar
2007 W221 S600, 2008 W211 E550, 2011 W221 S65 AMG, 1994 W140 S320
Thanks a lot for the response. Yes, the car sat for a couple of months before I purchased it. I am the second owner. I have since replaced the battery with an Optima Yellowtop DH7. I do agree with you on low battery doing all sorts, I experienced that coming from an S600 previously.
Nothing shows up on the scanner by way of fault both for the steering and the rear window blinds. Still Stomped.
Old Nov 29, 2024 | 12:04 PM
BOTUS's Avatar
S500
did u try moving the column in the opposite direction to the one you want ? - there is a calibration process - when confused it will not move at all in two planes (say out or down) till its been through full travel in the opposite two planes...
Old Nov 29, 2024 | 02:17 PM
Yeah, I tried that. It's not showing any sign of life. I should also add that the indicator on the end of te stalk doesn't light up either and there's no heated steering wheel as well. It would seem as though there's no power to the stalk itself.
That's why I was thinking maybe a fuse problem?
Old Dec 1, 2024 | 03:07 AM
JohnLane's Avatar
222 S-65
Find the fuses. Check them with a test light with an incandescent light bulb. A bulb sized as we had for a dome light in the 1970s is the right one. A ‘digital voltage probe’ too often lies where there is a poor connection such that it picks up 12 volts but the circuit is unable to pass enough amperage to operate.
Old Jan 2, 2026 | 06:52 PM
EasyPhil's Avatar
2007 S550 4Matic 2013 S550 Base
There's actually a simple fix for this when you hear a click when trying to adjust the tilt. Check out this video:
Old Feb 13, 2026 | 08:50 PM
stevE400's Avatar
2016 E400 4-Matic
Thanks for attaching that video Phil. Did that on my 2015 E400, and it worked perfectly.
