Strangest Oil Leak Ever
Old Jun 11, 2025 | 05:13 PM
rafaelq's Avatar
Angry Strangest Oil Leak Ever
Greetings All,
I'm experiencing the strangest oil leak I've ever encountered with my W221 - 2012 S 550. It has the M278.932 engine in it. I've replaced the sealant (RTV) on the valve covers and it continues to leak. The leak is occurring on the driver side near the coil/sparkplug nearest to the firewall. Just above the heat shield that covers the exhaust manifold, the oil is pooling on that heat shield, then dripping off onto the exhaust manifold and burning off. There is no oil pooling in that sparkplug well. There is NO visible damage to the block itself, we've inspected everything as I currently have the complete drive-train out of my S 550. I just can't seem to find where the oil is coming from. It only leaks while it's running. Has anyone ever seen this before? I'm at the end of my rope here. Thanks in advance!
Old Jun 11, 2025 | 05:34 PM
ChrisHimself's Avatar
SPONSOR
11 E550, 16 AMG GTS, 13 S550
its not the front timing cover at the top? thats the most common leak and its a known defective RTV seal from the factory. The finish prevents good RTV adhesion
__________________
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
Old Jun 11, 2025 | 05:35 PM
rafaelq's Avatar
Not that I can see thus far, we've crawled this thing and just can't figure it out
Old Jan 14, 2026 | 10:50 AM
Papushkian's Avatar
2009 S450, 2011 GL450, 2008 C300 Sport
Did you figure it out?
Old Jan 14, 2026 | 07:19 PM
Alexie's Avatar
Greetings All,
Check the camshaft solenoid seal directly above that area. Common on the M278. They leak while running and oil runs down the back of the head, pooling on the heat shield. Valve cover gasket itself can also seep from the very back corner. Since it's out, clean it bone dry, start it, and watch that solenoid.
Old Jan 15, 2026 | 12:31 AM
Max Blast's Avatar
NGL450 w/EORP, S550
If you remove the fake firewall, you’ll see it
