Parking brake reset
Last week an alignment was done after suspension work. The alignment tech unkowingly put on the parking brake. I now get the dash message and blinking "Park". The message can be reset with the steering wheel button but blinking PARK stays. It doesn't affect driving but is annoying. I searched for a shop with the right scanner to reset it but it could not be reset. I pulled the safety release cable in the fuel filler area . It comes out a few inches but it didn't do anything. Apparently the motor that pulls the brake cable does not sense tension/resistance of shoes against the drum (because there are no shoes). This makes the module think there is a problem and causes the message a.d blink. Is there a way to turn off the indicator without taking everthing apart?
https://nemigaparts.com/cat_spares/e...71/63v/42/045/
Failing that refit the hardware. Even a penny washer and JBWeld would fix the back plate permanently. Even a backplate from a base W204 would get the job done although you may have to remove the outer lip from the plate to clear the larger discs.
Mercedes mechanical rear parking brake hardware was pretty much unchanged across the board from the last Millennium until 2014 is when they went to the more stupid electronic caliper actuation.
Incidentally, if you saw the size of the parking pawl in the gearbox, you would immediately get your parking brake serviced and working properly. It won't take much force on an incline to snap it then it good bye car. Notwithstanding the total lack of E brake should you actually need one. And as a school bus driver, you of all people shouldn't need reminding about the responsibility that goes with operating a vehicle.
Rant over, but get it fixed.
