Buying a 2010/2011
Old Dec 31, 2025 | 07:14 PM
Max Blast's Avatar
NGL450 w/EORP, S550
It came to me with new oil and brand new engine air filters - I guess carfax reports are good for something.
Dance mom/participant PO did smoke in it though and it’s coming back so another ozone cure is in the cards then swap out cabin filters.
just put 75 miles on her in glorious pnw weather with a full cabin and not much issue with it from my kids so my nose is super sensitive to cancer stick usage I guess.
Old Dec 31, 2025 | 11:09 PM
Max Blast's Avatar
NGL450 w/EORP, S550
Hit a bump - esp now off.
codes out as a b24/15 yaw rate sensor failure (likely loose). I’m not at WIS right now and no specific location for this module in the w221 exists on the internet.
anyone know where it is?
cleared all errors and will see if it reappears.
Old Jan 1, 2026 | 02:08 AM
BOTUS's Avatar
S500
in the boot on the floor near the rear SAM - they are always about this point on cars
more likely an ABS wheel speed sensor wire doing what they do - although that ought to get a speed sensor error - but they often start to die or fail in one hit after large bumps
Old Jan 1, 2026 | 03:53 AM
Max Blast's Avatar
NGL450 w/EORP, S550
My thoughts exactly - wheel speed sensors burning out and subsequent abs and esp malfunction has happened quite a few times in my x164 but that is a line item under ESP…the only fault under ESP was yaw rate sensor B15/25. No wheel speed implausible stored or current codes found. Thanks for the location .
Old Jan 1, 2026 | 07:34 AM
Senecat's Avatar
1983 Nissan Shltbox
Putting your trust in reports with line items generated by shop monkeys isn't something I have any interest doing, myself.
All fluids are critical and get replaced immediately after a purchase, regardless. It's a peace of mind thing for me, and it's paid off in the past.
The history points to the b24/15 connection being directly under the unsealed region of your trunk and got a good shower or two.
Old Jan 1, 2026 | 08:56 AM
BOTUS's Avatar
S500
where I said
https://mbworld.org/forums/attachmen...990d1589826021
Old Jan 1, 2026 | 09:13 AM
  #32
Senecat's Avatar
1983 Nissan Shltbox
So opposite side. Coincidentally where the boot battery happens to live. So some bumbling shop monkey replaced the battery and knocked the sensor.
Maybe you can check your Carfax report and find out who to charge for the sensor replacement.
Old Jan 1, 2026 | 10:33 AM
  #33
Max Blast's Avatar
NGL450 w/EORP, S550
The 2010 doesn’t have a boot battery but I was just in there. Thanks for the WIS write up!
Old Jan 1, 2026 | 10:42 AM
  #34
Senecat's Avatar
1983 Nissan Shltbox
It seems as though we've circled back to my theory (:
That's what mine looks like too
Old Jan 1, 2026 | 10:52 AM
  #35
Senecat's Avatar
1983 Nissan Shltbox
I know you have WIS, but the guessing game is fun sometimes.
Small tangent; You know Xentry pretty well. Have you ever played with ride height?
Old Jan 1, 2026 | 11:58 AM
  #36
Max Blast's Avatar
NGL450 w/EORP, S550
only on x164 and only temporarily via manual calibration. The car will eventually reset itself to standard ride height. Mind you, these are the only options in standard Xentry - there might be a German language workaround in developer mode.
otherwise it’s lowering links to trick the airmatic ECU into thinking it’s at normal height, which I have not done.
Old Jan 19, 2026 | 04:04 PM
  #37
Max Blast's Avatar
NGL450 w/EORP, S550
Has anyone rebuilt an OEM Mercedes control arm on this board? I recently did the front lower rear arms and noticed within a week that the Delphi replacement arms are creaking, or should I say the ball joint is - bad on me for not checking the grease in them.
im noting the overall better quality of the OEM arms and wondering if the outer ball joint can be pressed or pullled out and a suitable replacement exists - because then I’ll just have two rotable sets of arms in inventory for when it chews through them.
also, got a know good yaw rate sensor from a wrecker in case this error presents itself again, but one week of driving and no errors.
i can also not find the sway bar bushings anywhere, which it needs.
Old Jan 19, 2026 | 07:53 PM
  #38
EasyPhil's Avatar
2007 S550 4Matic 2013 S550 Base
The ball joints aren't serviceable, the end that attaches to the knuckle..
Old Jan 20, 2026 | 02:50 AM
  #39
BOTUS's Avatar
S500
the main anti roll bar bushes were once a merc item - they fond they creaked and groaned and bonded then on to the arms - and thus are now only available as a whole arm with new bonded on bushes
after market sell bushes - unknown quality - either way they need to be glued on with a polyurethane glue - gorilla makes some
Old Jan 20, 2026 | 01:33 PM
  #40
Billydv1's Avatar
2011 S550 4matic
Im actually pretty sure it's my bushings squeaking. Im going to try the aftermarket ones in spring. Way too cold right now
Old Jan 20, 2026 | 10:40 PM
  #41
Max Blast's Avatar
NGL450 w/EORP, S550
I just bought Amazon bushings for 12.99. I’m gonna try to glue them on because the ones that are on there are absolutely wrecked.
It’s worth a shot before I shell out 175 for a new OEM front sway bar.
Old Jan 21, 2026 | 05:04 PM
  #42
Billydv1's Avatar
2011 S550 4matic
You know, I really wonder if they actually need to be glued. I think if you remove the 4 bracket bolts, scrape and cut off the old rubber material. Check the fit, if its snug and tight, I wouldn't glue. Most cars do NOT have glued bushings so I can't understand why we would need it on this Model.
Old Jan 21, 2026 | 05:07 PM
  #43
Billydv1's Avatar
2011 S550 4matic
And BTW,
if you do glue these in place, I believe you would absolutely have to do it with the wheels loaded, otherwise the bushings would not be glued in the right spot. If indeed they appear to need to be glued, I would have the car off the ground and level at all 4 Wheels and the car sitting on blocks or something else to make sure it's correct
Old Jan 21, 2026 | 06:12 PM
  #44
Max Blast's Avatar
NGL450 w/EORP, S550
Yep, as is true with all other bushings as well. This car is so low I’ve got to build even ramps or get it onto a 4-post lift to be able to tighten it up with load on the suspension at right height level.
Old Jan 21, 2026 | 07:27 PM
  #45
Max Blast's Avatar
NGL450 w/EORP, S550
Originally Posted by Billydv1
And BTW,
The X164 that I came from does not have these glued on and they are replaceable. This is the only car I know so far that has fused bushings, and the bracket actually holding them in place and sort of acting as a torsion rod.
Old Jan 22, 2026 | 01:41 AM
  #46
BOTUS's Avatar
S500
one of the very first TIPS docs in 2006/7 was a warranty fix to bond the bushes on just sold cars to stop ridiculous squeaks, groans and general racket coming of the front anti roll bar
Old Feb 26, 2026 | 08:27 PM
  #47
Max Blast's Avatar
NGL450 w/EORP, S550
So, greetings from the low side of things.
I have replaced the abhorrently squeaky sway bar bushings with an Amazon set ($25) and did not glue them on.
added to that two new lemforder sway bar links at 50 bucks each
Also, replaced both torque arm bushings with lemforder ones - just press the old ones out with the arm still attached in the ball joint ($75 for both)
But the key enabler of this was a dirt cheap bushing tool press kit on Amazon - it’s about 170 bucks and very well equipped. I had a set of Baum bushing press tools arrive at the same time courtesy of FCP euro and overnight shipping, but I ended up not even using this tool because the cheapo Amazon one was more than adequate.
now, kind reminder that you always torque everything back down with weight on the front wheels otherwise you’ll just tear the new bushings immediately.
And it’s really nice and quiet, and all squeaks is eliminated for about $375. The cool thing is that this kit has so many different diameter cups that I’m going to tackle the rear end with them as well and just find the bushings instead of brand new control, arms of dubious quality.
ZKTOOL 40Pcs Universal Pull and...
Amazon Amazon
I will say that my back is kind of sore, but this is entirely DIY with a floor jack and some wooden blocks and a couple jackstands.
Old Feb 27, 2026 | 04:11 AM
  #48
BOTUS's Avatar
S500
must be young - I have this think that there is no way I'm bothering to do anything on the floor any more
Old Feb 27, 2026 | 04:58 AM
  #49
AL5461's Avatar
W221 S500
https://www.amazon.com/dp/B0FMJM3145...p_mob_ap_share
My shoulders still have recurring nightmares from doing Omega suspension rebuilds on the drive😂
Have done a few clutch/gearbox swaps with little more than a trolley jack and ramps, but the 722.9 is always a shop job😉
The biggest issue with doing suspension work on the ground is getting the car high enough to be able to use a long enough bar to get the nuts and bolts undone. Although credit where it's due, my 132k mile 2006 S500 is cleaner underneath than my 2004 Vauxhall Omega (Catera for you Colonialists) wagon was at 5 years old🤐
Old Feb 27, 2026 | 10:09 AM
  #50
Max Blast's Avatar
NGL450 w/EORP, S550
Yeah, and the key job left to do is to do the center bearing support. I am noodling whether I just jack up the rear end and put it on blocks for roller access and use my transmission jack to download the exhaust system… or wait for some lift space at a friend of mine who is terminally busy with restoration projects. There is a notable vibration present at about 75 miles an hour. I can go 65 or 80 in comfort until such time.
I’m pushing 50 and a repair job like this carries with it a day in the penalty box if I use the creeper.
otherwise, the two other things left to do is to:
replace the rotation sensor behind the trunk panel - the incumbent has finally failed completely
Put the steering wheel back on straight, which necessitates a forensic investigation into which connection was broken in the past - whether it was steering wheel on the shaft or the shaft connecting to the steering rack.
Does anyone know whether the steering shaft to rack connection is a splined connection? I heard that particular disconnect was a six hour job with subframes, etc. etc..
