Found a cheap S-Class but what are these codes?
Old Feb 11, 2026 | 02:43 PM
ARL_350's Avatar
2015 ML350, 2020 BMW X7, 2005 LS430
Hey guys, title should say enough. Guy wants to offload the car as he has multiple others. I am attaching the codes below. I can do some basic work but don't want a buy a car which needs a whole engine job or anything major. I know these aren't cheap cars to play around with, but for the price it can be a justified beater that I could get some extra life out of. Please let me know what could be causing the codes and how serious they are/ how difficult it would be to fix. Appreciate it.
File Type: pdf
Old Feb 11, 2026 | 02:55 PM
BOTUS's Avatar
S500
why not paste the info as a picture or better still text - why do I want to open a potentially hooky pdf
delete all the info drive 10 mins real stuff will be back again
if no one ever cleared you could have thousands of codes from last 18 years
Old Feb 11, 2026 | 03:03 PM
Jaap's Avatar
2006 W221 S500L M273
Yeah i ain't opening a PDF from the web.
Old Feb 11, 2026 | 03:16 PM
ARL_350's Avatar
My apologies:NOTES : P0128 - thermostat temp life slowly
P0025 - Continuous camshaft adjustment ( LEFT ): Incorrect position of the exhaust camshaft (P0025) P0022 - Continuous camshaft adjustment ( LEFT ): Incorrect position of the intake camshaft (P0022)
P0015 - Continuous camshaft adjustment (RIGHT): Incorrect position of the exhaust camshaft (P0015)
Codes were done at a brakesplus not a real mechanic 2 months ago. Seller " allegedly" says it ran smooth prior to having the car sit for 4 months and no rattling although that could be wrong.
Old Feb 11, 2026 | 03:34 PM
BOTUS's Avatar
S500
camshaft fun is "normal" chocolate chains, idlers and cam sensors - might be nothing might mean end of the world
Merc stats like to age worse than most cars - silly electrical thing and three cooling circuits
Old Feb 12, 2026 | 12:21 AM
Max Blast's Avatar
NGL450 w/EORP, S550
It’s a 2007 innit
Old Feb 12, 2026 | 12:52 AM
ARL_350's Avatar
Originally Posted by Max Blast
It’s a 2007 innit
Nope 2008. Checked it out and tried to jump it but the battery wouldn't charge enough. It barely cranked but wasn't able to fully start. The car was being sold by the original owners son, the original owner passed away recently. The son listed the car for $1500 so I thought it was worth checking out. Might get AAA to come out and jump it if its not gone by the weekend.
Old Feb 12, 2026 | 04:23 AM
Jaap's Avatar
Worst case would be a stretched chain or the famous m273 idler gear problem.
Are you jumping the small battery under the hood or the big one in the trunk?
To start it, you should only jump the small one under the hood.
Old Feb 12, 2026 | 04:34 AM
BOTUS's Avatar
S500
check pictures to determine what set up your car has
twin battery cars have a monster 23kg battery hidden at the back of the boot
later single battery cars...
Old Feb 12, 2026 | 10:29 PM
Max Blast's Avatar
NGL450 w/EORP, S550
good deal even if for parts, but it probably has the incipient phase of the worn idler gear that some 2008 had and most of 2007s. It’s not necessarily catastrophic. I’ve driven some of these with a worn out idler gear, and all it does is tick. Or jump time and grenade itself - dealers’s choice.
pics or it didn’t happen.
