How does the door sill plate attach?
Old Mar 29, 2026 | 06:01 PM
RichDMB's Avatar
2008 S550
The sill plate for the passenger front door on my 08 S550 is loose and rattling; it's the front third of it closest to the front of the car. I felt underneath the plate and don't feel any tab and it's not held down by screws. I could always use a little construction adhesive, but I would like to do it the correct way if possible. Thanks in advance.
Old Mar 29, 2026 | 06:39 PM
RichDMB's Avatar
2008 S550
I googled it (gotta stop being lazy) and can see there are four fasteners, so the front one must have snapped. Easy fix.
Old Apr 1, 2026 | 04:31 PM
Alexie's Avatar
On those W221s, the front section of the sill plate is held by a metal spring clip underneath, not a tab or screw. The clip gets weak or the plastic receiver breaks. No adhesive from factory. Pop the whole trim up carefully, check if the clip is still there or if the plastic base is cracked. Replace the clip or the trim piece if broken. It just snaps back down.
Old Apr 1, 2026 | 09:08 PM
RichDMB's Avatar
2008 S550
Thanks Alexie, I just got some trim removal tools from Amazon and I'll get to it this weekend. Nice to know what to expect once I pop off the door sill.
Old Apr 2, 2026 | 05:12 PM
TimC300's Avatar
May have to start unclipping at the back:
