Oil in Control units
Old Mar 31, 2026 | 06:16 PM
2481977dullA's Avatar
mercedes s w221 350 2013
Good evening everyone out there,
I could use some help: With my Mercedes (W221 S 350 petrol, 2013), I keep finding oil in the control units, especially at the connection of the large plug.
How can something like this be fixed? Does anyone have experience with this?
THANK YOU
Old Mar 31, 2026 | 06:38 PM
BOTUS's Avatar
S500
you mean the metal ECU the air box sits around ?
that is a normal failure of the cam sensors - they leak - oil migrates down the loom and blows up the engine ECU ( AKA Bosch ME9.7)
clean the engine looms or replace it
replace all 4 cam sensors
fit blocking loom gadgets
hope the engine ECU survives
the oil mist / combustion gasses, acid and moisture filth that migrates often kills the engine ECU
Old Apr 1, 2026 | 04:29 PM
Alexie's Avatar
That’s classic Mercedes. Oil travels up the wiring harness from a leaking sensor usually the camshaft or crankshaft position sensor. The oil gets into the control unit pins by capillary action. You’ll need to replace the leaking sensor, flush the harness, and clean the control unit plugs. If you leave it, the control unit will eventually fail.
Old Apr 1, 2026 | 05:38 PM
JohnLane's Avatar
222 S-65
*Most people only learn of this as the control unit fails! OP if your control unit is alive you are ahead of the game!
Old Apr 2, 2026 | 09:20 PM
TimC300's Avatar
Do you see signs of oil in the camshaft position sensor harness or in the camshaft adjuster harness?
There was a "fix" with the M272/273 where an additional harness was added to the camshaft adjuster harness. Im not sure about the camshaft position sensors.
It looks like its the same harness for multiple engines, 272, 273, 276 etc.
What engine is in the S350, M276?
