Rear fog light W222,
Dear friends,
What are rear fog light, Mercedes Benz W222 ? If you have a photo,I would like to see it. Greetings from Bulgaria |
The US S550 does not have fog lights (front or rear).
Thanks !
i would say the rear fog light is the same as the rear fog light on the w221... the car has to have one, here in germany it is law. since it is made here, i dont see them leaving it out.
EXCEPT on the W221 there is a light switch to turn the fog lights on or off (including rear). That switch is removed on the US version; only the European version has the option, which is a push button to the left of the headlight rotary switch.
2 Attachment(s)
Had a very very close call so realize I need a rear fog.
Talked to Mercteil, it seems easy enough. Maybe with enough interest, we can do a group buy? http://www.mercteil.com/en/products/...t-kit-for-w222 S63/65 ~half of the 999 EUR of the diffuser kit S550 with sport package 999 EUR rear diffuser kit, which basically gives you the S63 rear end - AMG tail pipes, diffuser, ornamental moldings S550 standard requires a rear sport bumper and the rear diffuser kit - unsure how much a rear bumper costs PM me if interested Attachment 442583 Attachment 442584 |
Is the white section in the center rear Backup white LED lighting and the fog lights the Red left and right is lit up?
Also, does it connect to factory wiring? |
Originally Posted by Nice Ride
(Post 7044725)
Also, does it connect to factory wiring? As for factory wiring, I'm sure it's possible but I'm not sure how/where it is integrated into the car. I've had enough issues in past wiring additional lights to factory systems that I prefer installing a separate switch but to each his own. I usually go on the side of the steering column. |
1 Attachment(s)
Originally Posted by jenz
(Post 7044967)
As for factory wiring, I'm sure it's possible but I'm not sure how/where it is integrated into the car. |
From another post...
https://cimg4.ibsrv.net/gimg/www.mbw...4e38526965.jpg |
(Post 7049709)
https://cimg4.ibsrv.net/gimg/www.mbw...4e38526965.jpg https://cimg1.ibsrv.net/gimg/www.mbw...2406949894.jpg |
(Post 7049751)
Even better so there's OEM parts for non sport pkg W222s, including picture here
Not a good idea to have your rear mounted fog light on all the time.
It's very bright and thus dazzles anyone following. Many US drivers not familiar with this light as few, if any, North American built cars come with it. Thus some drivers are not aware its even there, some drivers drive with it on all the time and a few knowledgeable ones deploy it as intended. The problem is driving with the light on when visibility is good, oft times is cause for road rage. |
