S-Class (W222) 2014-2020
Need an update on WiFi
Old Jul 24, 2014 | 09:54 PM
AppleFan1's Avatar
2025 EQS580
Alishami, please read my edited post just above. There is no doubt in my mind that it's using the car's WiFi when I have it activated.
Old Jul 24, 2014 | 09:57 PM
Alishami's Avatar
S500 2015
Well,the best way that you could test if the iPhone is using the car Wi-Fi or not is to turn off the celluar data in your phone and connect to your car Wi-Fi and then try the iTunes radio
Old Jul 24, 2014 | 10:02 PM
whoover's Avatar
'19 E63S sedan
I just touch the "Media" button on the command area and then the system connects the device (iPhone in this case) through bluetooth and it starts playing streaming music from the music stations I had selected on iTunes Radio. Without any doubt at all, there use to be a big difference with and without connection to WiFi. It was so bad in the past that I would deactivate the WiFi in the car so that I could just stream the music through the At&T data plan and 4G LTE connection. But recently, I do not need to deactivate the WiFi since it works good enough. Is this just a coincidence? I don't think so.
Btw, the phone has to be getting connection through the car's WiFi because when I try to go to a couple of different websites on the phone while I'm sitting in the car, it is quite slow as opposed to the normal 4G LTE it normally uses when it is very fast. But evidently, the WiFI is now just fast enough to be able to stream the music from iTunes Radio quite well as opposed to the past.
It really sounds like it's now going through your phone's 4G connection and data plan and not the previous mBrace 3G connection. The way to know for sure is trying this with the phone far away from the car.
Old Jul 24, 2014 | 10:10 PM
AppleFan1's Avatar
2025 EQS580
If I'm far away from the car it will change from the Mercedes connection to the AT&T 4G LTE connection. How does that prove anything? Isn't it convincing enough that web browsing on the phone while sitting in the car (the WiFi symbol is showing and on the phone and on the WiFi settings is says connected to Mercedes) is very slow. When I deactivate the WiFi in the car, browsing the web is now very fast since it's using the AT&T data. To me that's 100% proof.
Old Jul 24, 2014 | 10:20 PM
MTrauman's Avatar
'25 S63 AMG E Performance, '26 CLE 53 AMG
In the top right of your right car display do you have two gold arrows pointing in opposite direction? This indicates that your car is connected to Verizon Telematics with an internet connection.
Old Jul 24, 2014 | 10:52 PM
AppleFan1's Avatar
2025 EQS580
Talking
Thanks for saving me Trauman! The answer is a big YES! I knew this to be the case all along but I just drove the car around the block to get away from my home WiFi and the 2 gold arrows popped up on the upper right hand side of the car display screen. And, on the iPhone WiFi settings it clearly states MB WLAN followed by a number. I have been trying to say this on about 10 different posts. As I said before, I was 100% certain that my phone was being connected to the car's WiFI as long as I have that feature activated.
So with all this confusion above, I have a feeling that the car's internet speed is slightly faster in recent weeks and that's why I am able to stream the music from iTunes Radio with much better luck while using the car's WiFi connection.
Man I hope this settles it this time. But I would love to hear from any of you about this issue.
Old Jul 24, 2014 | 11:55 PM
  #32
nyca's Avatar
4G on your phone is always going to be much faster that the car's WiFi using 3G for its uplink. You aren't going to see good connected car app performance until the car has a 4G head unit, and this 2015 model year car doesn't have that.
Old Jul 25, 2014 | 09:37 AM
  #33
AppleFan1's Avatar
2025 EQS580
Yes I realize this.
But I thought that perhaps the speed could be improved by some sort of software update. I think something to improve it slightly has already been done by either Verizon or MB per my "zillion" comments above.
Old Jul 25, 2014 | 12:25 PM
  #34
whoover's Avatar
'19 E63S sedan
Just to be completely sure, in the above test run did you leave your phone at home as well? We want to absolutely eliminate the possibility that the phone, not mBrace, is supplying COMAND with the internet connection.
(Or just turn off the phone's Bluetooth.)
Old Jul 25, 2014 | 02:45 PM
  #35
AppleFan1's Avatar
2025 EQS580
Ok, I just did another test with the iPhone left in the house. I drove around a few blocks and when I went to launch MB Apps, sure enough the 2 golden arrows showed up on the upper right hand corner of the screen as usual. The only App that I have now is the Google Maps. They obviously disconnected all the rest probably in early July along with the Internet Radio.
