S-Class (W222) 2014-2020
Garage Door opener range
Old Oct 28, 2015 | 03:26 PM
jmrdmd's Avatar
2021 C63S Cabriolet, 2021 GLE53 Coupe, 2022 GT3 Touring, 2021 Taycan Turbo S, 2022 F-150 Lightning
Hi All
I have a 2015 S550 and the garage door opener seems to have a greatly diminished range over my 2014 SL550 and my other non MB cars. I mean that the car has to be almost touching the garage door! Does anyone have this problem and a fix for it?
Jan
Old Oct 28, 2015 | 03:56 PM
Wolfman's Avatar
Super Moderator
Originally Posted by jmrdmd
Hi All
Jan
Have both cars and both have more or less the same range (within 6-10ft). Openers work fine within a 50ft range.
We have Chamberlain openers.
I have read that some extend the range by using a longer wire on the opener. Maybe it's time for a new opener or add a wifi interface and then use the phone to open it.
Old Oct 28, 2015 | 07:33 PM
RajwanyS550's Avatar
2015 White/brown Nappa S550, '13 S550 4 matic, 11 S550 sold, '10 S550 Sports BLACK 08 S550 P3 sport
try stripping a little of the antenna wire on your garage door motor. had the same problem, now works fine. Mercedes has low range for garage door openers.
Hi All
Jan
Old Oct 28, 2015 | 09:35 PM
Wolfman's Avatar
Super Moderator
I guess that in the eye of the beholder...
We have 3 MB's. All cars open the garage doors before the cars get to the driveway and our BMW 750li was no better than the MB's, so I figure that the variable might be the garage doors, the openers or other interference.
Some openers might just be more sensitive to transmission signal strength than others.
Our Chamberlains are better than our old Genies, plus I like the battery backup. Work great during the occasional power outage
One thing I did notice; some buttons I have to hold longer until the opener responds (always the same door, so it is the opener).
Old Oct 28, 2015 | 10:42 PM
emilner's Avatar
S560
My wife's GL can get the door to open when approaching the property 100' from the opener. My S550 you need to be within 40-50'. And heaven forbid you miss it or try too early, when I do I'm stuck trying for 5 minutes to get it to go....
Old Oct 28, 2015 | 10:45 PM
Streamliner's Avatar
I completely agree with the OP. My previous 2013 S550 & my current 2015 S550 must be FACING my garage door, within about one car length away from it, for the signal to be received. While our 2004 SL500, 2010 E350 & our 2016 E350 will open the doors without facing them and from 3 or 4 car lengths down the alley. I do not know what to attribute this to.
Old Oct 28, 2015 | 10:53 PM
xrayaz's Avatar
1988 560sl/2015 S550 4Matic
I must agree that my S550 seems to be on the weak side. My 2008 w221 would open my door and the gate at my sisters from much further away. I recently had a Ford Escape that also would work from quite a distance.
Michael in Arizona
Old Oct 28, 2015 | 11:45 PM
nycphotography's Avatar
'15 T&C & '14 SL63
The CLK63 worked from the end of the driveway.
I never bothered to program the T&C because it never gets to sleep inside, so I can't speak for it's range.
The SL63 won't program... so I'll be stopping by the dealer some day to have THEM program it. Odd that it won't program though.
Old Oct 29, 2015 | 06:59 AM
jbattan's Avatar
2023 Mercedes EQS 580 SUV, 2023 Bentley Bentayga, 2023 Genesis GV60
None of my four MBs are good with Homelink distance. My 2005 Lexus is vastly better, able to open our estate gate from 150' away.
Old Oct 29, 2015 | 08:04 AM
jmrdmd's Avatar
Thanks for all of the replies!
Jan
Old Oct 29, 2015 | 08:52 AM
SteveE400's Avatar
2015 E400 and 2015 GLK350
There is one variable not mentioned here - the construction of the garage door itself. All of my openers used to work from 3 or 4 houses away, until my wife decided that it was time for a new garage door. She chose a steel door, which seems to act like an RF shield. After installation of this door, the range of all of our openers decreased noticeably. I do notice, however, that the "clickers" that came with the Chamberlain opener work faster and from a greater distance than do either of the MB devices. Ours still open from the far end of the 120-foot driveway, though.
Old Oct 29, 2015 | 08:59 AM
lh713's Avatar
2015 GL63, 2015 S550, 2006 SL55
My garage door opener service company advised that the use of LED bulbs or compact fluorescent bulbs in garage door openers reduces the distance significantly because of interference.
Old Oct 29, 2015 | 10:16 PM
platt-deutsch's Avatar
2019 S450
I wonder how the bulbs would affect it if they dont come on until the opener is activated?
Old Oct 29, 2015 | 10:33 PM
steveb9771's Avatar
2007 CL550
A while back this issue was discussed on the W221 thread. The special UV protective coating on the windshield glass reduces the range of the Homelink transmitter which is located in the rear view mirror. This coating on the glass also interferes with toll road transponders which will only work if they are located small uncoated region of the windshield.
Old Oct 29, 2015 | 11:39 PM
Wolfman's Avatar
Super Moderator
MB uses the UV coated glass for 15 years now.
Old Oct 31, 2015 | 04:40 PM
Wolfman's Avatar
Super Moderator
I was curious about these very different experiences that we have with the same type car and did a quick check again with our cars (13 SL550, 14 ML350, 15 S550). Only the S-Class has the UV coated glass afaik.
Our mailbox is on the side on the property and about 70-80ft (line of sight) away from garage doors. When pressing the button the car stand sideways from the doors, not facing them.
All cars opened the doors at that distance. The S worked about the same as the others, if not a touch better.
All three cars had trouble opening the door closest to them, I assume because of the stucco wall being in the way. Had to hold the button longer on all cars.
This mirrors what the BMW did as did our prior models (S, CL, SL). Some with had UV coated glass, some didn't.
All of our opener bulbs and soffit lights/sconces uses LED bulbs. btw.
I assume these different experiences must be contributed to the different building materials, RF interference, and opener models rather than particular car models.
Old Oct 31, 2015 | 08:14 PM
'15 T&C & '14 SL63
Stopped at a dealer today.... I swear it took him 15 seconds to program the damn thing (doing exactly the same thing I had tried over and over and over again with no luck).
Anyhow, no worries as that's one thing I won't have to bother with again.
Old Oct 31, 2015 | 09:13 PM
My four garage doors are solid 1.5" thick wood. W221, W222 need to be right in front of the door to work. Pretty much ANY other vehicle works from 50' down the alley.
Old Nov 2, 2015 | 12:20 PM
WEBSRFR's Avatar
Tesla Model S P100D
I believe this will solve your problem and it costs only about $30:
Liftmaster 41A3504 Residential Garage Door Opener Antenna Extension Kit - Garage Door Hardware - Amazon.com Liftmaster 41A3504 Residential Garage Door Opener Antenna Extension Kit - Garage Door Hardware - Amazon.com
The problem is not with the Mercedes transmitter but your garage might be well insulated from RF signals (Can you get a cellphone signal when your garage door is closed?)
The antenna extension will greatly extend your operable range of the garage door.
Old Nov 2, 2015 | 01:07 PM
emilner's Avatar
S560
The issue is certainly with the car in my case. My wife's GL has double the range on the same doors. My previous cars and trucks all had much better range. Only my 222 has limited range.
Old Nov 2, 2015 | 08:37 PM
Warehouser's Avatar
2023 S580 Selenite
Exactly what I ordered and installed for my Chamberlain, made a big difference on my S.
