As others have said, the car overall is pretty solid but still get an warranty as small stuff will fail even with lower miles. My aftermarket warranty has been successful in covering some small yet expensive repairs.
Not a common failure. The part is 2K reman MB. Plus the install. I researched the turbo price after I bought as I understand it can be a maintenance item if kept into higher miles. 2-5K is a lot cheaper than buying a new S560 every 3 years for me.
OP
Third party warranty is a buyer beware world for sure. However, there are good ones to be found. Try your local Credit Unions. They have already vetted the warranty vendors for their membership. My third party covered struts, ball joints, motor/trans mounts. Bought the warranty thru local Credit Union. Good luck. |
45k on mine. Had to replace the rear suspension(airbags). Apparently there was a recall on them. Would have been a 5k job with parts and labor if it wasn't under warranty. My advice? Find a slightly used 2015 or above from the Mercedes CPO site. Unlimited mileage warranty for a few years after the factory warranty expires at 50,000 miles. I don't buy these cars new because the CPO is a MUCH better deal!
Originally Posted by mysticblu999
(Post 7704628)
Any one out there with high miles now? I'm at 96k trouble free miles! Plan on keeping this car and wearing it out.
I have 126k on my 2008 s63 and planning to go for 200k+. Maybe I’m crazy. It has been warrantied up until now, always dealer repaired. I will start working on it myself and using a local import shop when I need help. I have virtually no experience working on cars but I am a software engineering so hoping some of the skills transfer. |
Originally Posted by Katie22
(Post 7707234)
60000 miles on my 16 Maybach and very little issues. Been a good car. I do all the maintenance on the car myself and its good stuff. I refuse to waste my money on an extended warranty. Please try to understand they people that sell extended warranties MAKE MONEY on that stuff and sell them based on fear............. Do the MATH and you will see warranties are a waste of $$.
Originally Posted by Josh Matthews
(Post 7806147)
Doing the maintenance yourself is key here. I’m hoping to learn how to work on my 2008 now that the warranty is expired. But over the life of the car my $7k maxcare warranty ended up paying for over $40k in repairs, so I think the can be worth it with these cars.
So, did you get the car? What were your learnings?
I bought a CarChex Titanium bumper to bumper aftermarket warranty for $6,200 (24 payments same as cash) 6 years 50,000 miles for my 2011 SL550 this year. Paid for the 5 repairs no problem first 9 months. Dealer wanted 6,000 for a 1 year MB warranty
When my 2016 S550 factory expires I will buy one for my S550. |
Originally Posted by gregorynp
(Post 7940138)
Originally Posted by chassis
(Post 7940508)
gregorynp, what were the repairs covered by your warranty? Thanks.
They will require aftermarket parts if avail. I use a local mechanic but could go to dealer. They don't pay diagnostic charges or tax |
(Post 7940655)
Rear strut, Something in the power steering that made a winning sound, blower motor wine in dash, Truck part that closed the trunk the last 1/4 inch.
Originally Posted by MBNUT1
(Post 7940835)
Did the sum of these repairs exceed the cost of the warranty?
(Post 7940835)
275K-miles (and counting).
2014 W222 4matic |
Originally Posted by ChesapeakeLimo
(Post 8728354)
2014 W222 4matic |
Originally Posted by HockeyPlayer
(Post 7455272)
My questions:
Are these cars reliable, especially with higher mileage? How expensive are they to maintain? Coming from AMG's and BMW M cars would I get bored driving an S Class ? Has anyone come from a BMW 750, Audi S8/A8 or Jaguar XJ ? How do they compare with the S Class? Compared to my Ferrari, the S-600 is DIV 3 to DIV 4 expensive. MB maintenance = Ferrari maintenances / 3..4 Compared to my Toyota, well the Toyota has cost 0 to maintain over the last 3 years..... You might enjoy the difference between a car you command, and a car that gets you there completely without fuss. Why would anyone ever want a modern Jaguar........... |
I have 78k miles on a 2016 S550. The following has been replaced.
Lower front control arm Upper timing covers engine wiring harness due to leaking cam shaft position sensors that wicked all the way back to the ECM ECM due to the above issue as well as a bunch of other parts that were damaged from the oil leak All turbo coolant lines aux radiator for the turbo main coolant reservoir Don't kid yourself, these are not reliable vehicles. They are complex and things will fail and they will be expensive to fix. That is what comes with the territory. |
I am in Bergen and I also commute in crappy traffic.
some days I leave early or have a meeting that takes me out west and I can sail a bit. I have a 2019 with 51k on it. I’ve had no real issues. i work on my car as much as possible and have replaced. Spark plugs air filters/in and out Temp valve wiper blades belts and pulleys. The car is rock solid. If you can diagnose and work on it yourself there is no issue. if you have a friend or client who has a lift, even better. most of my clients are transportation companies so they love when I come in with this beautiful car to do some work. The mechanic always jumps in because he is also in love with Benz. |
Originally Posted by Mitch Alsup
(Post 8728434)
2015 S65 with 106,000 miles....
Front suspension arms at 90,000. Brake pads at 93,000. Love the carbon ceramic brakes. All fluids with regularity. Spark plugs. Heater sucks. Good thing all those surfaces warm up at the press of a button.... and that it doesn’t really get cold here in the valley. The 221 S65 ate front suspension arms every 30,000 miles. Brake rotors were forever warped... I’m a savage. Engine spat a main bearing shell into the chains at 78,000 miles. That was a treat to replace. Got to replace a heater blower motor and fan controller... a radiator, a voice recognition ECU. Alternator died a month after the radiator. Nothing like getting to pull that radiator again! A/C compressor died at 130,000 miles. Lots of fluids. Never had an issue with ABC. |
(Post 8728434)
My 21015 S-600 has been exceedingly reliable.
Originally Posted by vinflouen
(Post 8728658)
Originally Posted by Donnymac
(Post 8728974)
Thats excellent for a town car. As it should be, nothing but wearables.
I drove my previous 2015 S550 up to 75K miles.... Not a single major repair during that time except two things: Charcoal fuel filter, and later at 70K miles one of the control arms (upper or lower) needed to be replaced. I sold it "as-is" to the dealer at that time because the cost to repair it was $3K+ with labor and it was time to trade-in anyway for another toy. Super reliable!
My current S560 has 33K miles, no repairs at all except the following minor repair: Coolant hose clamp that needed to be tightened. I had a 2006 S500 back in the days --> This one was a nightmare but served me up to 180K miles. |
