S-Class (W222) 2014-2020
ABC / MBC Oil flush and filters
Old Jan 6, 2019 | 01:31 AM
alexdou111's Avatar
DESIGNO CLS 63 AMG 2012
Hi,
I am Alex living in Cyprus (an island in the mediterranean Sea)
I bought a 2014 S500 L some months ago with about 45k miles on it
My car comes with the ABC or MBC system. I have read loads of threads of chagning oil of the ABC system is super important
as otherwise the hardware will wear off and break eventually causing quite expensive repairs and spare parts.
Has anyone does such change on a w222 yet? I have bought the oil and searched the net for procedures to do it and my problem is
A) I found it only for older cars w220 or R230
B) they mention a magnet filter to add to attract abbrasive metal part but there is no such filter for the w222 models and I am trying to find out what metal filter could fit.
So I wonder what experience or knowledge may exist her ein the forum for the process of ABC oil change on our W222 ?
Thank you for your participation in the thread.
Old Jan 6, 2019 | 07:46 AM
Katie22's Avatar
18 AMG GTC and 22 F150 Limited. Past owner 16 Maybach, 17 Brabus Smartcar, 06 Ford E150, and 22 G70
I live in the states and that service is not called for till many many more miles beyond what you have. If you feel compelled to do the work you can buy a copy of Mercedes WIS on ebay and the directions are there on how to do the work.
Old Jan 6, 2019 | 01:44 PM
Nice Ride's Avatar
2014 S550 AMG, 2017 XT5
A few older videos... Just give you an idea of what goes on...
Old Jan 7, 2019 | 04:03 AM
alexdou111's Avatar
nice, thanks for the videos.
Can we do a Rodeo mode on our w222 by any chance?
I guess would need to have a STAR Diagnosis system in place?
othweriwse have you been able to up or lower your ABC just by holding the button from the interior?
Because I tried and nothing really happened for me.
thanks for any further input!
Old May 27, 2019 | 02:14 PM
bkdc's Avatar
2015 S550, 2017 GLS450
I'm going to resuscitate this thread because I also have questions regarding a flush on the W222 ABC system (Magic Body Control). I don't mind a DIY but I'd like to see it done on a W222.
It is my experience that fluid accumulates sludge far sooner than when the manufacturer recommends a service. You should see the crap that comes out of the "lifetime fill" rear differential.
Old May 27, 2019 | 03:43 PM
Utopia Texas's Avatar
2019 SL550/2023 EQS 580 SUV
In my opinion Mercedes dropped the ball so to speak on original mileage recommendations for flushing out the ABC systems. I bought my 2008 SL550 used in 2013 with 35k on the odometer and the supposed light green ABC fluid was jet black with globby particles mixed in. For a company supposedly so meticulis about maintenance the recommended time interval for changes was way too long especially considering the ABC system and power steering system used the same pump with separate fluid reservoirs for each system.
Old May 29, 2019 | 05:43 PM
bkdc's Avatar
I read through the WIS. In the W222, there is no replaceable ABC filter. To replace the filter, the entire hydraulic fluid reservoir must be replaced as the filter is integrated into the reservoir.
There is no procedure to flush and replace the fluid. The WIS calls for a filtering process in which the hydraulic fluid reservoir is first replaced. Then a filter process is performed to pass the existing hydraulic fluid through the new hydraulic fluid reservoir. Then the hydraulic fluid reservoir is again replaced.
This requires two new hydraulic fluid reservoirs and a STAR diagnostic system. This is seriously cumbersome. I don't mind a process that replaces the reservoir, but is there no simple process to flush the old fluid and replace it???? There may be a way to rig the return pipe into a bucket with the standard flush. I don't know whether the two hydraulic pipes are two-way (fluid flows both ways) or whether one is the inlet and one is the outlet.
https://mbwis.net/en/doc/7057021
Old Oct 9, 2021 | 04:16 AM
Echudu's Avatar
S500
W222 abc fluid flush
Hi guys just joined the forum and seeking your help regarding the fluid flush on a 2015 w222 s500/550 with ABC. Was anyone able to do it?
would be great if you can also share your experience with having the suspension option. Any issues faced.
thanks
echudu
Old Jan 22, 2023 | 04:13 AM
heuyewhang13's Avatar
V220
Hi,I am interested on ABC suspension maintenance,intend to buy one.
thanks
echudu
I just intend to buy one after Chinese new year W222 2014 Malaysia
Old Jan 22, 2023 | 03:21 PM
JohnLane's Avatar
222 S-65
With my 221 S65 I opened bleeders for ABC (engine off.. car set to max height) to dump fluid into my brake bleeding bottle (a big one). The car drops that corner. Start the car and repeat until she is ready to have fluid refilled and fresh fluid comes out. Repeat with each of the bleeders.
The 221 car had a replaceable filter. What problem got solved by making us replace the reservoir? Grrrrr.
Old Jan 24, 2023 | 11:29 AM
VII's Avatar
VII
2020 S560, 2014 SLK55 (Prev. 2016 S65, 2013 SLK350, 2008 CLS63, 2006 E350, 2006 CLS500, 2005 C230K)
The idea with the revised setup is that fluid degradation is not a factor for system failures but rather foreign contamination and the conclusion was that this was workshop or user caused.
The idea is then to reduce reasons for workshop or user to open the system and improve filtering of fluid.
​​​​Color change is due to rubber hoses and would not indicate a problem in itself.
