S-Class (W222) 2014-2020
Can the air freshener canister be filled with something other than from the dealer?
Old Jun 20, 2020 | 07:54 AM
dpm7471's Avatar
2019 S560
I have a 2015 S550 with the air freshener option that is in the glove box. My canister is empty. I had someone tell me that one can fill it with any kind of scent of there own without the need to buy a $100 or more new one from the dealer. Is this true and how do you do it?
Any help would be appreciated.
Old Jun 20, 2020 | 09:28 AM
hyperion667's Avatar
2012 CLS63
Yes, try some Fois gras juice
Old Jun 20, 2020 | 09:50 AM
Donnymac's Avatar
63 Falcon vert
Fragrance = Houston taxicab.
Old Jun 20, 2020 | 10:34 AM
Katie22's Avatar
18 AMG GTC and 22 F150 Limited. Past owner 16 Maybach, 17 Brabus Smartcar, 06 Ford E150, and 22 G70
I use essential oil stuff that I brought at Pier 1 but I think Wal Mart has it too.
Old Jun 20, 2020 | 10:58 AM
as.thompson's Avatar
Veteran: Air Force
S550C4, Porsche Cayenne
Originally Posted by dpm7471
I have a 2015 S550 with the air freshener option that is in the glove box. My canister is empty. I had someone tell me that one can fill it with any kind of scent of there own without the need to buy a $100 or more new one from the dealer. Is this true and how do you do it? Any help would be appreciated.
It's easy. I have done it in my '16 S550 coupe.
The top of the container is difficult to unscrew. But if you cut the seal around the cap and use enough torque it unscrews like any typical jar. I use alcohol-based, off-the-shelf New Car scent spray that I got from the local car parts store and just pour it from the spray bottle into the jar.
Don't use oil-based scents as the heavier oil can gum up the tubes in the system.
Old Jun 20, 2020 | 12:32 PM
2012 CLS63
Gum Allow these to protrude from the air vents
Old Jun 20, 2020 | 12:51 PM
Donnymac's Avatar
63 Falcon vert
Need one that blows bubbles.
Old Jun 21, 2020 | 09:26 AM
fun33's Avatar
2017 550SL - 2018 560S
Any Yankee Candle Diffuser Oil will work. The OEM fluid is oil-based not alcohol, which would evaporate extremely quickly. Very simple to remove the lid, just cut the 1" wide clear seal on the OEM container.
Old Jun 21, 2020 | 01:03 PM
superpop's Avatar
2019 S63 4Matic+, 2018 E400 Cabrio, wardens car.
I purchased a bottle of Tommy Bahama fragrance oil at the TB store and fill it with that. 22 bucks and it smells great.
Old Jun 22, 2020 | 02:42 PM
Veteran: Air Force
fun33, I stand corrected.
I had always read that the original scent was alcohol based. So that is what I have used with good results. But after reading your post I checked one of my scent containers - Freeside Mood - and it is definitely oil based.
So I learned something new today. Thanks.
Old Jun 22, 2020 | 07:15 PM
MBS63AMG's Avatar
2019 S560, 2022 Audi S8
I do it all the time. I use my cologne in the bottle so that I don't have conflicting fragrances. I happen to use Curve cologne. I also notice the fragrance more so than the MB products.
Old Jun 22, 2020 | 10:58 PM
superpop's Avatar
I have found that most cologne only lasts for a few months before the cologne evaporates because it is alcohol based. The scented oils work much better and last for a long time, much like the factory scents.
Old Jun 23, 2020 | 08:33 AM
2012 CLS63
Wonder if you could infuse your own scent into an oil based liquid.....maybe on the stove; low heat.
Old Jun 23, 2020 | 01:07 PM
superpop's Avatar
I recommend Hot-Dog water.
Old Jun 25, 2020 | 03:14 PM
fun33's Avatar
Urban Naturals
I ordered a scent called "Warm Vanilla Amber" made by Urban Naturals from Amazon.
https://www.amazon.com/gp/product/B07B9Z3QLR/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B07B9Z3QLR/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Personally, I think it's perfect. $15.99 with free shipping. They have 28 different scents to choose from. I cleaned out my original MB container with alcohol to remove the OEM scent. You received enough oil to totally refill your MB Container four to five times.
Old Jun 25, 2020 | 09:44 PM
Donnymac's Avatar
63 Falcon vert
Amber once worked at Centerfolds in Houston. I heard the scent was expensive.
Old Jun 26, 2020 | 08:16 AM
2012 CLS63
Guessing Amber is your old lady?
Old Jun 26, 2020 | 08:43 AM
dpm7471's Avatar
2019 S560
Thank u fun33. I appreciate the help.
Old Jun 26, 2020 | 08:54 AM
Donnymac's Avatar
63 Falcon vert
Never took a test drive.
Old Sep 29, 2021 | 08:54 AM
ALANPRIEBE's Avatar
2020 E53 CABRIOLET 2021 S580 (TRADED), 2023 EQS580 SEDAN SEDAN
Just got my 2021 S580, installing my fragrance jar, is there a seal on the jar or do you just take out of the box and install?
Old Sep 29, 2021 | 09:46 AM
2012 CLS63
You can also water down some Comet and use that
Old Sep 29, 2021 | 12:10 PM
cfmistry's Avatar
15 S550 4Matic, 86 560SL
If you use alcohol-based fragrances, as I do, you can expect them to last 2-4 weeks. If you use oil-based fragrances it can last upwards of a year. Just FYI.
Old Sep 30, 2021 | 04:27 PM
ALANPRIEBE's Avatar
Question: On a new canister do you just take out of the box and install or is there a seal on the jar that has to be removed before you install? I installed, it on the limit and smell nothing?
Old Sep 30, 2021 | 05:44 PM
DaveW68's Avatar
Veteran: Army
2015 S550
No seal. Just take out and install. I've noticed that I never get a whiff of the scent unless I'm taking a fairly sharp turn. I think the bottle has to be shook up to emit the scent.
Old Sep 30, 2021 | 06:04 PM
ALANPRIEBE's Avatar
Thanks for the info, that makes sense seeing that the top openings have a sponge like material, I'll give it a good shake, thanks again!
